LS3 engine, new cam no real HP gain?
#43
john .if your valve train was real noisy.i would pull a head to see if you had valve to piston clearance issue.possible down on power dew to exhaust valve being bent.had same problem with mike t vette.or do a leakdown with the rockers off.after you reinstall cam.
#44
No update yet.
What keyway are you refering to?
I borrowed a boroscope to check out the tops of the pistons for any unusual marks. Plan to do a leak down on the engine as well, we just used a piston stop and degree wheel to find TDC.
#45
St. Jude Donor '11-'12-'13-'14
I think he means the keyway on the crank snout.
If the cam was installed incorrectly, I feel like you'd have much worse problems on your hands than a little down on power. I still think it was ground incorrectly
#46
I am on pins and needles waiting patiently.
I'll be honest I didn't look close but I don't think there is a key way on the snout, think that's why everyone pins the pulley in place? Or maybe there's a key way on the snout and not on the balancer, on my buds lt1 vette we had a key way laser cut into the balancer holder so his Vortech would stop throwing belts, that was 20 years ago .
#47
There's a keyway for the timing gear so you can align the cam, but no keyway for the balancer, which is why blower guys pin them.
Often times the new timing gears come with a variety of keyways so you can degree the cams...you should pull yours down and make sure it's not 2 degrees retarded. I've been quiet but I suspect that is your issue.
#48
The LS3 crank has a keyway for sure. I almost post poned my build when I saw it so I could pin it while I was down there.
This is a blurry pic, but you can see it at the 1 oclock position.
#49
There's a keyway, but no key. I remember thinking that I had lost it when I pulled off the OEM balancer. I had to research it on here to see if there was one present from the factory.
#50
I thought for sure I had a pic of the cam/crank being lined up so I could have someone verify it for me but I don't know what happened to it. I could have sworn there was a slot on the end of the crank but I've been wrong before.
#51
OEM gears come with those provisions? My 3 bolt cam gear only installed one way but I know John went the other route and had to convert to a single bolt cam gear. Perhaps they're different?
He's lucky he didn't lose a balancer going down the road.
#52
Ya, this whole incident wreaks of suck.
I think John had an OEM single bolt cam gear installed as he mistakenly ordered the spin cam cut on a single bolt instead of a 3 bolt.
The cam being retarded certainly isn't out of the realm of possibilities. I'm really curious to see what the cam doctor reveals. If it is in fact the correct grind, I'll be mind-boggled. Installing a cam isn't exactly technically-challenging
#54
the three bolt and single bolt cam sprockets line up perfectly, no way to get that wrong, I'll be going back to a three bolt, all parts are here except cam and I actually have one for my 5.3 turbo engine I have been staring at but it's on the small side.
My Meziere Corvette pump showed up today as well, they do nice work but they charge for it, when this car comes back out it either going to be a beast or it's heading east.
#56
I have a 1980 Mercury Zephyer (think Grandmas Fairmont, same box) with a transplanted 5.3 LS with a large frame 72 mm turbo and built 4l80 that is now running, dual 3" aluminum exhaust, not a looker until the hood pops, then you hear, holy and **** used together , bingo anyone?
#60
It's no muscle car, it's a box with lot's of horse powers .... Need to swap cam and valve springs, should dyno around 650 rwhp @ 14psi ans weighs about 3k lbs right now. I have 17" Billet specialties for it and will have 275/40/17 drag radials on "Z" back.
