GS Launch Control / My experience
Hi Everyone!! I just recently bought my girlfriend a 2010 Black/Black GS 6M 2LTwith 6136 miles on it. It's a nice car and I enjoy the way it drives and she does as well. She and I also happen to think Corvettes are one of the prettiest cars on the road.
The other night we went for a ride and we decided we would try the launch control. I have watched videos on how to do it a few times and it seemed simple enough to try it myself. So I stop, put the car into Competitive Drivng mode, push in the clutch, put the car in first gear, floor the accelerator, and let out the clutch. What happened next was anything but controlling a launch. It just incinerated the rear tires. So now it's just dancing off the rev limiter, right foot still glued to the floor and I think that's when I started to laugh. Very quick into second but with a throttle lift and back down again and the tires are still spinning without any type of traction control/launch control intervention whatsoever. So all the way to the top of 2nd gear and the car really hasn't moved all that far yet, maybe 80-100 feet I am guessing, and I just breathe out of it, put it in third and casually head down the road. So after that we both said we won't do that anymore. I actually felt bad for the car and the tires.
Can anyone shed any light on the operation of launch control and what, if anything, I could be doing wrong? I won't be trying it again actually. Just feels way too abusive to the car. I really just wanted to see if it worked and my early conclusion that on our GS it does not.
Does the car have a M2W controller for NPP exhaust? If yes, was it in the "W" (loud) mode?
If yes to that too, then switch it off, to "M" (quiet)(stock) mode.
It does have the optional exhaust but I was unaware that it had a controller. I don't know where it is if it has that. All I see in the car is a button in the center that turns on and off the TC/AH or puts it into competitive driving mode.
Found it:
http://forums.corvetteforum.com/c6-c...em-solved.html
So maybe you just didn't get the procedure exactly right. Try again or take it in to be checked and watch the mechanic test it. Nothing else to offer at this point. Sorry.
Received 8,956 Likes
Bill
Correct me if I'm wrong, but I thought launch control wasn't available on the GS until 2011. You were using the correct procedure as I recall, but your year model didn't offer that feature.
By the way the mild to wild controller has nothing to do with launch control.
http://www.youtube.com/watch?v=qVf2RRhhrkY
That's why I figured our car had it. Maybe it was an option?
The revs did not level out at all. Basically went to the limiter and I dropped the clutch. I didn't know how it worked so I wasn't sure if that was correct or not. I thought to myself there is no way this is going to work at this RPM and sure enough didn't work.
There was a discussion a few months ago about one of the Corvette techs at MacMulkin telling a member that was why his LC didn't work correctly. I'll see if I can find it.
Found it:
The M2W is an after market item. If you didn't buy one then it doesn't have it.
Found it:
Thanks for posting this. I searched and for some reason I didn't see this post.
I will just take the car in and see what they tell me.
One thing I do find interesting though is that it had no traction control intervention of any kind regardless of the fact that launch control didn't work.
I sure did and I don't mind beating a car a little to get it moving but starts that violent make me cringe. Like I said, we won't be trying that again. Both she and I can get the car rolling just fine without any electronic nannie help.
And glad you roasted the tires, instead of your halfshafts, tranny, or some other more expensive component. Your worst enemy is wheel hop; if you didn't have any, your car should be fine.
It looks like you basically did a 6500 rpm clutch-dump burnout. I'll bet there was plenty of smoke, lol.
Anyway, next time just watch the revs and make sure they are held at 4K automatically (so you know launch control is active) before you release the clutch. I know on the BMW //M cars with launch mode, there are a number of prerequisites that must be met to activate the system (engine temp, etc.). Not sure about the C6.
She really likes the car. It's one of the prettiest cars on the road and the previous owner took especially good care of it so it is nearly immaculate or was until we got our hands on it!!
Thank you for everyones input here as now we have a clear understanding of what the dfferent modes are for TC/AH and what we can expect the car to do. Thanks again!
