(OIL COOLERS), C6 variants, LS2/Z51, Z06, ZR1??
Old 03-23-2012, 12:41 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
Default (OIL COOLERS), C6 variants, LS2/Z51, Z06, ZR1??
Wanted to be clear on the OEM oil coolers available for the C6
1. Z51/LS2(in radiator)
2. Z51/LS3 same??
3. Z06 air to oil, mounted up front in front of rad/cond.
4. ZR1??
Thanks for clearing this up. If anyone has pics, that would be great.
Old 03-23-2012, 02:26 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
2. Z51/LS3 same??
4. ZR1??
2006-2010(Ithink) Z06's have the oil cooler heat exchanger mounted in front of the condenser. The ZR1 and Z06 from 2011^(I think) use the radiator coolant running through a heat exchanger mounted on the side of the oil pan in front of the oil filter.
Old 03-23-2012, 03:41 PM
Motorhead-47
Support Corvetteforum!
Motorhead-47's Avatar
Z51 coolant-to-oil radiator
Z51 external air-to-oil
Z06 air-to-oil
Z06 coolant-to-oil
I've lost track of which years have which. It gets very confusing.
Old 03-23-2012, 03:54 PM
SteveDoten
SteveDoten's Avatar
I believe the LS3/2008 was the Z51 changeover to air
thanks for the pics
Old 03-23-2012, 03:56 PM
JRHAWK9
JRHAWK9's Avatar
mine's an '08 Z51 and I have the air to oil......
Old 03-23-2012, 04:02 PM
Motorhead-47
The manual transmission Grand Sport used the Z06 air-to-oil for a while. Not sure what the current model Grand Sport manual trans uses. Auto Trans Grand Sports never got the cooler. I think the Z06 went fluid-to-fluid in 2010-ish timeframe.
Old 04-06-2012, 09:55 AM
franman69
franman69's Avatar
I have a 2007 with Z51 and I'm concerned with Oil temps.. 230+ during spring time spirited street runs.. Is the external Air-Oil cooler an option for me?? Would it be better than the inside the radiator oil cooler that I believe my 2007 Coupe has?? I'm concerned about oil temps at upcoming HPDE events...
Old 04-06-2012, 10:45 AM
franman69
franman69's Avatar
I just read on C6 Performance Corvette's page that the 2007-2009 Z51 package did NOT have a EOC option?? Is this true.. does my 2007 Z51 car not have any additional EOC built into the radiator?? Anybody know. I'm thinking about adding an aftermarket oil cooer.
Old 04-06-2012, 11:01 AM
JoesC5
JoesC5's Avatar
Check just above the oil filter for two hoses running to the front of the car.
Old 04-06-2012, 11:06 AM
franman69
franman69's Avatar
yep.. that makes sense... (I was just under there the other day... should have looked, but I was sure the car had an oil cooler).
Old 04-06-2012, 11:43 AM
Mike's LS3
Mike's LS3's Avatar
I posted this same response in another post:
My 0EM 2008 manual Z51 has three oil coolers:
1. External engine oil cooler
2. External power steering fluid cooler
3. Integrated cooler with radiator for manual transmission oil.
Old 04-06-2012, 12:14 PM
el es tu
el es tu's Avatar
2. Z51/LS3 same??
4. ZR1??
ZR1 gets this one:
I believe the gs gets this one:
ZR1 and Z07 also get a better radiator
Old 04-06-2012, 04:39 PM
Motorhead-47
Originally Posted by el es tu
ZR1 gets this one:
Later model Z06's got the first one above.
The small one is a Z51 only oil cooler..not sure what all years though....2008 for sure.
The GrandSport, at least for 2010 got the large Z06 full width cooler...that is IF you ordered a Coupe with a 6-speed manual/dry sump engine. Like I mentioned earlier...the number of different combos hurts the head.
Old 07-01-2012, 09:24 AM
SteveDoten
SteveDoten's Avatar
Z06 added the oil to coolant unit in 2010?
Old 01-06-2014, 01:02 AM
1999bluer6
1999bluer6's Avatar
Default >>>
I have a 2008 c6 z51 manual trans and mine has the radiator hook ups and the smaller black oil cooler. I haven't looked down by the oil filter yet but i know for a fact mine has those two.
Old 01-06-2014, 12:23 PM
JasonS5555
JasonS5555's Avatar
ALL the M6 dry sump GS had the large "Z06" style air/oil cooler. For some reason GM didn't swap them over to the ZR1 style cooler....
HTH,
Jason
Old 01-06-2014, 12:28 PM
timd38
timd38's Avatar
Buy a 2006-2009 Z06 cooler and lines. It will bolt right in.
To (OIL COOLERS), C6 variants, LS2/Z51, Z06, ZR1??
Old 01-24-2016, 09:58 AM
HamadoZr1
HamadoZr1's Avatar
I need Zr1 oil cooler upgrade, can someone tell me the name or website or whatever?
Old 01-24-2016, 11:30 AM
timd38
timd38's Avatar
Just go to the dealer and get 2011 ZR1 heat exchanger. Not sure if it will work because of the way it bolts to the block.
Old 01-24-2016, 01:21 PM
HamadoZr1
HamadoZr1's Avatar
I would go to the dealer but I am not from US😅 Always I'm ordering from outside and I live in Dubai
Quick Reply: (OIL COOLERS), C6 variants, LS2/Z51, Z06, ZR1??
