Pfadt Johnny O'Connell Signature Suspension
Old 07-27-2012, 12:52 AM
  #41
piran21
piran21's Avatar
Would you recommend the Johnny o'connell setup for a C5 with the F45 suspension?
Old 07-27-2012, 12:44 PM
  #42
Pfadt Racing
Pfadt Racing's Avatar
Absolutely! If you're looking to replace your F45 shocks the Johnny O'Connell Stage 1 would be a very good fit. Keep in mind that you will need to disable the F45 system with the GM Tech2 tool to tell the system not to look for feedback from the shocks... but other than that it would be a great upgrade. You should call around to some local dealers and see who can perform this quick change in your area, but once the system has been disabled the Johnny O'Connell package will bolt right up and function great just as it would on any other Corvette.
Old 07-27-2012, 03:28 PM
  #43
DJCobol
DJCobol's Avatar
Getting ready to order this setup in the next few weeks. Anything else that would be beneficial to replace/upgrade at the same time while everything is apart? Brake lines? Bushings?
Old 07-27-2012, 04:00 PM
  #44
Pfadt Racing
You can definitely do a brake job while you're in there. The JO kit does include replacement poly sway bar bushings and endlinks, so those two bases are already taken care of.
Really other than routine maintenance there isn't much touched during the JO kit installation that isn't either reused or replaced by the kit. It already replaces quite a few maintenance items, so unless other systems need attention there isn't much left to do unless you wanted to build the car a little more aggressively with Poly Control arm Bushings or a Camber kit for track use.
Old 06-14-2013, 02:17 AM
  #45
deanna2008
deanna2008's Avatar
Would you recommend this package for a C6 Z06 also?
I wonder if the benefits are less than putting it in a stock c6.
Old 06-14-2013, 09:59 AM
  #46
Blue Demon Owner
Blue Demon Owner's Avatar
See the video on the PFADT website on the JOC suspension package page. Johnny developed the package on a C6 Z06. I certainly love it on my Z51!
Old 06-15-2013, 02:02 PM
  #47
bktmbill
bktmbill's Avatar
I also have JOC stage one package and really like it. The car does sit about 1/2 inch lower whitch i also like. I was wondering if anyone has installed the rear shock spherical bearings from pfadt and if there is any gain with handling or is it only with coilovers does this show improvment.
Old 06-17-2013, 11:41 AM
  #48
Pfadt Racing
Shoot me a PM or post up what you would like to improve. There may be a better option if you are looking to improve your handling even more.
Old 07-11-2013, 05:03 AM
  #49
bobworld007
4th Gear
bobworld007's Avatar
Originally Posted by Pfadt Racing
There will be a small change in ride quality due to a change in bar stiffness, but by far the biggest drivers in ride quality are going to be how the shocks are valved, and to a smaller extent the spring rates being used. The car may feel just a little bit stiffer when hitting a road irregularity with one side of the vehicle and not the other on a stiffer sway bar, but overall their impact to ride quality isn't nearly as big as other components in the suspension. Everyone's perception of ride quality is going to be different, but in our experience a sway bar change isn't a significant impact to ride quality.
The JO package is great! If you ran it for a year the worst case scenario is that you sell the shocks on the forum for less than what you paid, but you still got a years worth of use out of them. Since there is no fabrication involved in installing either package you can easily move from the JO package to Coilovers. In fact the JO sway bars would be a pretty good fit for a street car that does move to coilovers.
Has anyone installed The Johnny O'Connell Sway bars in a 2013 427 Convertible?
Old 07-15-2013, 06:17 PM
  #50
WannaC5Z
WannaC5Z's Avatar
Ok so I don't have $1000 bucks to blow on car parts at the moment. However I do see that you can purchase the shocks separately from the anti-sway bars. Which should I buy first?
Old 07-16-2013, 03:36 PM
  #51
WannaC5Z
WannaC5Z's Avatar
Anyone?
Old 07-16-2013, 04:01 PM
  #52
sallen619
sallen619's Avatar
Anyone?
Sway bars 1st...
Old 07-16-2013, 07:10 PM
  #53
mikeCsix
Support Corvetteforum!
mikeCsix's Avatar
Fantastic! I'm so glad you're enjoying your new suspension package. We really do love the results from the Johnny O'Connell stage one.
I'm a firm believer in Pfadt products, I've seen your new website, are you planning to have links to your wheel alignment and anti-sway bar charts?
Old 08-03-2013, 09:28 AM
  #54
bobworld007
4th Gear
I Just had mine installed at ESC in NJ... They made a tremendous difference...Love them on my 427 Convertible...
Old 10-22-2015, 01:48 AM
  #55
mtomlin1
mtomlin1's Avatar
Hi Guys,
I have a 2006 Z06, i do about 15 track days a year and currently am unsure what package to go for.
obviously the stage 1 is great value for money but are the coil overs going to be worth the extra 2500 USD?
any advice would be great.
Also is there any major difference between the two sets of Sway bars you can buy online? , one seems thicker than the other.
thanks
Matt
Old 10-22-2015, 09:34 AM
  #56
LFZ
LFZ's Avatar
Originally Posted by mtomlin1
Hi Guys,
thanks
Matt
For a C6Z and serious track...I'd stay away from any Pfadt products and go with something a little more serious that is proven.
If you're wanting to stay with just a shock swap...DRM makes a 'Z06 specific' valved Bilstein shock that is just wonderful on a C6Z.
A good set of coils will always be the ideal way to go if you're budget and/or driver experience allows for it. Otherwise...a set of DRM shocks and perphaps some Strano or Hotchkis sways to start off with will transform you're Z into something that will inspire more confidence thus reducing lap times.
Old 10-22-2015, 04:27 PM
  #57
mikeCsix
mikeCsix's Avatar
Mtomlin1, Are you trying to correct an issue?
Quick Reply: Pfadt Johnny O'Connell Signature Suspension
