2006 Corvette A6 H/C/I LS2 Dyno
Been playng around with this car for close to a year. The car is a 2006 Corvette convertible LS2 with an A6 auto transmission.
The car has 2.56 rear gears and is a blast to drive.
Additions
- Comp cam 223/231 610/617 112
- Fast 102 unported with a stock 90mm LS2 T/B
- LS3 Injectors 41lb
- TFS 220's BTR untouched other than milled to 63cc for 11.1 comp
- Johnson 2110 Lifters
- Yank ss3600 stall
- 1 3/4 LG Headers and catted x pipe
- Corsa Exhaust.
This is a dyno dynamics dyno pull with 12.5 afr and 24 degrees of timing max. The converter was locked.
This was the first dyno a couple years back with the converter locked. This was all mods with the exception of the TFS 220'S
This was a second dyno last June which was more for Tranny tuning. The converter was unlocked and all modifications except TFS 220'S.
Additions
- Yank ss3600 stall
- Corsa Exhaust.
The following 2 users liked this post by z06scentair:
Brandon619 (03-10-2017),
sallen619 (03-07-2017)
Nice numbers, keep the LS2 alive!
The car is very fun to drive. With a larger cam I'm confident the car would have made closer to 500whp which is quite the feat for an auto.
Received 2,061 Likes
Nice numbers there. Looks like that could be a 10 second car.
The locked vs unlocked converter appears to be ~30 HP difference with a 3600 stall. People don't understand that concept. I lost 17 HP on the dyno and dropped .15 seconds off my 1/4 mi time when I swapped from a 3600 to a 4000 stall.
If I was racing the car I'd jump to a 4000 converter and swap the cam. It's mainly a street driven car. The 3600 is all I would ever want in its current usage.
It's amazing how far converter technology has improved over the years.
Thanks for the kind words.
