Center Console and Radio Bezel Removal
Old 02-01-2012, 02:16 PM
SinisterC6
SinisterC6's Avatar
Paper clip tool ftw! The cigarette lighter always slows me down.
Old 02-21-2012, 12:54 AM
Daekwan06
Daekwan06's Avatar
Awesome thread. Thanks for the hard work!
Old 02-21-2012, 01:41 AM
cdkcorvette7
cdkcorvette7's Avatar
Old 05-02-2012, 10:42 PM
vettecdr07
vettecdr07's Avatar
Default Write up
Thanks for that great write up. I am installing the new Mgw shifter this friday. This write up is going to make this shifter install a piece of cake. Bravo Zulu.
Old 05-02-2012, 11:31 PM
cdkcorvette7
No problem. You're going to love that MGW. They are the hands down the best shifters on the market.
Old 05-04-2012, 05:03 PM
vettecdr07
vettecdr07's Avatar
Default Tech info
Just installed my MGW shifter with the help of this write up. The bezel was off in under 15 min. The shifter was in in no time. Thanks for all of your hard work CDkcorvette7. Everything went right on this project thanks to you. All the best.
wideglideleon (09-22-2020)
Old 05-04-2012, 06:30 PM
Bedouin
Bedouin's Avatar
Yep, this was hugely helpful for removing the console form my '12 GS...Thank You!!!
Old 05-04-2012, 10:14 PM
TNTC4VETTE
Will work for HPDE time.
Support Corvetteforum!
TNTC4VETTE's Avatar
Changed the bushings on my shifter box today. Thanks for the great writeup!
Old 07-27-2012, 02:26 AM
BOUT X
Corvette Cowboy
BOUT X's Avatar
cdkcorvette7 Thank you for the write-up I am C5 owner but my friend Bought a new shift ball and needed me to cut down his stock C6Z06 Shifter down and put a 9/16-18 thread on it so he can use his new Shift ball so to you great write up 15 min. to get it out.
Pops
Old 07-27-2012, 04:27 AM
taken19
Track Junky
taken19's Avatar
Great write-up! Thanks for your contribution.
Old 07-27-2012, 04:35 AM
Keith Tedford
Keith Tedford's Avatar
Default Video
For those of us who don't visualize the written word very well, MGW has a pretty good Youtube video showing the console top removal for a shifter install. It's pretty well the same as the pictures above. Perhaps a little easier for some of us to understand exactly what is going on. http://www.mgwltd.com/corvette_short...allation.shtml
Between these pictures and the video, I think pretty well anyone, including me, could do the console removal with confidence. Thanks for your pictures.
Old 07-27-2012, 05:20 PM
cdkcorvette7
Pops
Old 07-27-2012, 06:26 PM
  #33
SUB VETTE
SUBVETTE
SUB VETTE's Avatar
Concur on great write up! I would also endorse the contributor above that said you can simply swing the bezel over into the passenger footwell without fighting the connector for the cigarrette lighter/accessory plug. No need to remove that connector unless you want to totally remove the bezel from the car.
Old 08-03-2012, 01:37 PM
  #34
ZO ZICK
ZO ZICK's Avatar
Great Write Up
Heading to the Garage to remove mine and connect Ipod adapter
Old 12-19-2012, 08:46 PM
  #35
FRChilln
FRChilln's Avatar
Great write up
Old 12-20-2012, 02:09 PM
  #36
PCMusicGuy
PCMusicGuy's Avatar
Originally Posted by cdkcorvette7
I know this has been covered before but I couldn't find any decent write-ups with pictures using the search function. Since I had to take console apart anyway on my 2007 coupe to install an iPod gateway I thought I'd document the process.
Which iPod gateway did you install. Any pics after the install?
Old 12-20-2012, 04:01 PM
  #37
cdkcorvette7
I used the ISGM575 kit from PAC Audio. It's their PXAMG interface with all the harnesses needed.
Sorry, no pics of the install process but it's really straightforward. Just follow the steps in the write-up above then remove the radio and A/C head units, set the dip switches on the gateway per the instructions in the manual and plug it in, run enough wire out to get your iPod where you want it then put everything back together.
To Center Console and Radio Bezel Removal
Old 03-24-2013, 05:39 PM
  #38
Le Mans Z06
Le Mans Z06's Avatar
Great write up, I just replaced mine with one of the carbon fiber consoles. The cigarette lighters are definitely a PITA.
Old 08-09-2013, 03:32 PM
  #39
IAmWill
Cruising
IAmWill's Avatar
Thank you. This helped a lot!
Old 11-09-2013, 07:26 PM
  #40
Chevy-SS
Chevy-SS's Avatar
Thank you very much for the nice pics and writeup! I can't believe how much searching and Googling I had to do to find this page.
Well done!!!!!!!!!!
Quick Reply: Center Console and Radio Bezel Removal
