Opinion on built 421 stroker HP
I recently had a 421 stroker motor installed in my 07 C6 A6 and just want some opinions of the HP it made, I feel it should of made more but maybe I'm wrong.
It's a TSP 6.0L 421 stroker iron block with Ls3 stage 3 heads ported and polished, 11.5:1 pistons, comp cam duration 231 247 lift .617 .624 113 lsa, Fast intake manifold, 60# injectors, 25% under drive pulley, SLP 1"3/4 LT no cats and B&B bullets, Yank 3600 stall. HP tuned on a mustang dyno.
HP is 469
TQ is 483
I was under the assumption it would of made 500 HP to the wheels.
Any comments would greatly be appreciated.
HP is 469
TQ is 483
HP is 469
TQ is 483
HP is 469
TQ is 483
What intake are you using?
Just curious if that is dyno jet numbers or mustang dyno. Mine made 520 on a dyno jet. Also I was told to add about 50 more rwhp do to the torque converter,which would be 570 total. Something about the dyno doesn't accurately read the power do to the 3600 stall.
HP is 469
TQ is 483
HP is 469
TQ is 483
You have more tq than hp too. That will be a very fast vette you are driving. A Ten second screamer with good tires and gear
I guess I'm the first one in this thread that would be REALLY dissapointed with those numbers.
Hopefully the dyno just reads low and it'll go run mid-low 10s and 130mph all day long. If it doesn't then you spent a lot of money on a turd.
HP is 469
TQ is 483
HP is 469
TQ is 483
I concur with most of the opinions on here...Mustang dyno (-20 to 35hp) and loose converter (-15 to 30hp) is what makes it read low, but go to the track with a decent tire and see what it does. If it runs the number, then all else is immaterial.
Thanks for all the posts guys, I spoke with my tuner today and he said exactly what most of you guys said. It's just the way the dyno reads it with the auto and stall. He said it will run mid 10's all day with a good slick. Now I have to go buy tires and run it! : )
HP is 469
TQ is 483
HP is 469
TQ is 483
Pump gas and I just did a 1800 mile trip and got 22 mpg at 80 mph.
Yours seems low for sure.
I have not run it at the track yet. But I have run several of my friends that have superchargers and one guy that has a Susuki GSXR 1000 and I've pulled on all of them!! It's exactly what my tuner said, don't pay attention to the dyno numbers, it's just a tool to tune your car. He said my car is a low 10 second car and I now believe him. Lol And I a solution love the motor!! No issues whatsoever and it has tons of power and torque.
You built a big stroker, strokers are torque makers. You cannot compare cubic inches here, you have to realized a strroker engine creates a lot of torque. Torque is acceleration. with that stall you are gonna runs some great low Et's. Get sticky slicks, air them down, heat them up and let'r fly!.
PS, you may also be dissapointed in your MPH, don't. ET's are the name of the game!
Have fun with that stump puller....
_Sloth Whisperer_
OP, did you get this thing to the track yet?
Have a cookie. Your setup is in no way whatsoever like the OP's, and bares no resemblance to his build. Your numbers are irrelevant. But good job though.
I got a Katech 427 stroker short block and installed a set of Trick Flow 225's and a ported 92mm Fast with 12.3 comp 8.7 dcr, Cam is a 236/240 613/598 i think, my RWHP is over 600.
