11.47 @ 122mph at Infineon with PICS!
Old 01-30-2012, 06:30 PM
firefighter813x
firefighter813x's Avatar
Default 11.47 @ 122mph at Infineon with PICS!
We purposefully tried to stay under 11.5 because I do not have a 5-point cage.
Mods are AFR 205;s, 224/224 115, vararam, stock LS2 intake, stock converter, Hoosier's on 17" C5Z wheels, 18" front wheels, ARH 1 3/4", Corsa Sports, stock UDP, etc.
I have a Fast 102mm intake and a 3800 2.5STR FTI converter going in soon.
Old 01-30-2012, 11:14 PM
LS9Drew
LS9Drew's Avatar
good stuff man, any dyno numbers?
Old 01-31-2012, 07:41 AM
turboffr
turboffr's Avatar
St. Jude Donor '10
Nice job.
Old 01-31-2012, 08:17 AM
firefighter813x
as is, 420/420 unlocked. Hopefully I can take it back to the track with the Fast 102 and torque converter before I leave to go overseas. I'll have to run at Sac Raceway because the cars been "kicked out" from Infineon Raceway due to the lack of a 5-point cage
What's a good 5-point cage for the C6 chassis?
Old 01-31-2012, 08:46 AM
matt_lowry123
matt_lowry123's Avatar
St. Jude Donor '11
Good job dude!! That's fast
Old 01-31-2012, 09:31 AM
hungryhippo
hungryhippo's Avatar
People seem to run faster at sac raceway.
Old 01-31-2012, 09:45 AM
LS9Drew
LS9Drew's Avatar
Ya you shouldn't have any issue at Sac, good luck
Old 01-31-2012, 09:56 AM
dennis50nj
dennis50nj's Avatar
nice times, the RSD 5 point
Old 01-31-2012, 10:00 AM
FloydSummerOf68
FloydSummerOf68's Avatar
So 122mph was on the brakes?
Just making sure I understand correctly.
Old 01-31-2012, 06:59 PM
firefighter813x
Correct! thesubfloor was hitting the brakes at the end of the run for two reasons: to get as close to the 11.5 dial in and to not go faster than 11.499 due to the lack of the roll cage.
So, he did hit the brakes on the 11.47 run. The car was super consistent and seemed to be getting faster as the day went on.
He was leaving at only 1000 RPM on all launches on the stock converter. We're pretty sure that we could of had at least a 11.3xx run if not faster with more time tuning.
Old 01-31-2012, 07:00 PM
firefighter813x
I'm thinking of this one too. I just found out that there's a forum sponsor that sells them here in Vacaville. I'm not sure if it's RSD or a vendor that sells RSD's products, but they're local!
Old 01-31-2012, 07:51 PM
Steve@RSD
Steve@RSD's Avatar
St. Jude Donor '13
FireFighter,
We are located in Vacaville. We can help you out with all your safty needs. We are the Manufacturer of the only NHRA Legal Bolt-in Roll Bars for the C5 & C6 Corvettes.
They come with Swing out & Removable door bars. We make 5 points and 6 points. They are Chrome moly and only add 42 lbs to your car.
Steve
(707) 365-0117
Old 01-31-2012, 07:56 PM
FloydSummerOf68
Ok, glad to hear it...I was wondering why the MPH was so low.
When will you get back out and run it all out to see what it can do? Won't the track give you a slip and tell you not to run anymore if you do one all out pass at the end of the night?
Old 02-01-2012, 12:35 AM
firefighter813x
Originally Posted by Steve@RSD
FireFighter,
Steve
(707) 365-0117
Do you have documentation stating that it's legal?
Old 02-01-2012, 12:51 AM
Dragracer_Art
Dragracer_Art's Avatar
122MPH is 10.90 territory with a decent 60ft. (1.50's)
If you were on the brakes @122... you definitely have a solid 10-sec ride there.
Old 02-01-2012, 03:00 AM
firefighter813x
I have no doubt that the fast 102 and TC sitting in my garage will get the job done. I just need to find the time to install the parts and buy some rear drag wheels/tires.
Old 02-01-2012, 03:26 AM
LS1LT1
LS1LT1's Avatar
Nice pics, and Christopher's car is always fun to watch make some passes.
True, but that sixty foot is going to be key and he of course won't see 1.5s (maybe not even 1.6s) on the stock stall.
The converter alone should get you into 10s but along with the FAST intake it will drive the point home even harder.
To 11.47 @ 122mph at Infineon with PICS!
Old 02-01-2012, 07:46 PM
stanger383
stanger383's Avatar
St. Jude Donor '09
Not sure how hard it leaves but my 05vert went 10.78@122.48(not on the brakes) so far my best MPH has been 124.33 and I have run10.78-10.90 about 25 run so I'm sure you have the power to go 10s if u can get a good 60 and 330 time
Old 02-01-2012, 09:47 PM
Dragracer_Art
One word:
NITROUS.
Old 02-02-2012, 05:00 PM
Steve@RSD
Steve@RSD's Avatar
St. Jude Donor '13
Yes, The NHRA Rule book. We developed this Roll Bar with guidance from several NHRA Inspectors, including Ken Gentry from the NHRA Chassis committee. no roll bar or roll cage can be documented until it is installed. There has not been any RSD Roll Bars installed that did not pass tech. The key is install it correctly as per the instructions.
Steve
Quick Reply: 11.47 @ 122mph at Infineon with PICS!
