I searched but came up empty handed. Does anybody know where a good write up is to install a hardwires mild to wild switch to control actuators on a z06 exhaust installed on a base c6?
I have a 05 3lt non npp car that never came with actuators but I'm installing a z06 exhaust that has the actuators amd I would like to be able to control them by the flick of a switch manually
I'm kinda wondering if I'm going to have to make this product.
I have the Sunset Orange Creations DIC controlled exhaust switch on my LS2 with Z06 exhaust. It works with a push of the DIC reset button and will remember the last state it was in on start up. Install was easy.
Ok, but i read the description 5 times it is not actually for a car without NPP. It plugs into the fuse under the dash and runs an on off switch to that fuse. I could do that for 15 bucks. I need a vacum controller.
