What repairs/replacements should I focus on first
5th Gear
Well, finally, after 40+ years of desire, I now have my Corvette. I want to start working on improving the car, mainly to reduce the necessity for repairs in the future. I realize the car is built well, and has some quality components, but I am sure many of them can be replaced with much higher quality components that will last longer and be more reliable.
What I would like to know is what the members here think are some of the easiest replacements that can be made to add reliability to the vehicle? Is upgrading the brakes a good idea? Should I replace the air intake with a K&N? Should I replace the front suspension or rear suspension?
I have a 2006 with selective ride control, so I don't know if I want to start playing with the suspension right away. I was considering upgrading the brakes first.
What does the Corvette community recommend?
There are a (very) few aftermarket parts that are arguably longer-lasting, but do you really want to (for example) go through the ordeal of pulling your working harmonic balancer now just to avoid the possibility of doing the same job later?
One very easy thing you can do is not leave your gas tank under 1/2 full for long periods. It promotes oxidation of the right fuel tank level sender, which is a pain-in-the-*** to fix.
Drive the car. Driving the car regularly, combined with frequent attention to the fluids (oil, trans, coolant) is the best thing you can do to keep the car running. Don't be afraid to push the Happy Pedal as far down as it will go on occasion.
Since you said "reliability" several times (and not "more performance") I would NOT fix or replace anything that isn't broken or making noise - but every so often you can imagine a problem, take the money you would have spent, and then put it into a savings account for when the time comes and something does actually break. Replacing or "upgrading" things is usually when something goes wrong IMHO: like upgrading swaybars and having your end-links go out because you didn't pay attention to their alignment on the re-install.
Don't over think it, just enjoy the car.
5th Gear
Interesting that right out of the gate most people simply recommend that the car be driven regularly and cared for well, and that parts be replaced/upgraded after they break. I appreciate everyone's advice. I think I will focus on the interior of the car for a little while. Minor improvements like a leather wrapped center console cover and maybe leather wrapped door handles. I'll make changes to mechanical stuff when it goes bad.
Received 2,046 Likes
St. Jude Donor '13
If you don't know the history, I'd change the fluids (oil, trans, diff, clutch[?], coolant, brake fluid flush). Just stay with the recommended GM fluids, they have have millions of miles of success, but the diff fluid has a new part number and needs no additives. Brakes may need work depending on mileage and useage.
Then, start putting miles on that puppy. Fix anything that breaks. Enjoy!
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
forget big brakes or whatever, and if you want a little more stopping power, change pads to something like some of the hawks or my choice, porterfield r4s.
start saving up for new tires, depending on where you live could be A/S or max summer. michelin makes good ones in both categories. saving up due to 1200-1600 cost for a set of four.
get an alignment. check on here and find either the "modshack" specs or pfadt street specs. silicone lube all the gaskets/seals around your car.
did I say change all the fluids?
Buy a factory service manual @$110.
Then get some jacking pucks/ jack and lift the car so you check the torque on every suspension/ cross member bolt and nut you can find.
Give the two fuse boxes a once over. Check the wires down at the starter and the negative battery cable. Even check all the ground wires..I think there are at least 6. Tighten the oil pan bolts and lube the sunviser mirror covers...really.
Then as above fluids, filters, battery, lube hinges and treat all the weatherstripes (w/ di-electric grease +1). The serpentine belt and hoses wear well.
When ever I personally buy a used car I immediately swap out all the fluids... Engine Oil, coolant, transmission fluid, clutch, brakes, differential. That way you're working on the same baseline and you know for a fact the last time all the fluids were done. Past that really take a minute to evaluate the car and what you want to do with it. If you want to drive the car exclusively on the street you may not need a big brake kit, but the stock brake hardware with new rotors and aggressive street pads may work really well for you. If you're looking to take it out to the road course pick up a set of dedicated track pads and swap them for your track days, otherwise just enjoy the car. For heavy track use, especially with race tires a big brake kit is a fantastic idea.
We've got your suspension needs taken care of. If the car is starting to get up there in mileage it's amazing what a complete suspension refresher can do for the car. For street and light track day users our Johnny O'Connell package includes new Upgraded shocks, Upgraded Sway bars, metal endlinks and sway bar bushings all in one neat package that will take your overall suspension performance past that of the C6Z. Not only can you increase the performance and fun factor of your new Corvette, you can swap out commonly overlooked maintenance items like the endlinks and bushings!
