Questions on headers
Old 12-14-2011, 06:10 AM
Venom_C6
Venom_C6's Avatar
Default Questions on headers
I found a set of headers for a really good price but they are for a z06 LS7, I have a 2011 Grandsport LS3 A6. Can anyone tell me if these headers will fit my car? Thanks in advance
Old 12-14-2011, 08:18 AM
2009CSR #45
2009CSR #45's Avatar
They'll fit but you may need to cut & weld at the axle. Most zo6 headers run a 3" mid pipe and I believe the GS's have a 2.5 " midpipe.
Old 12-14-2011, 09:59 AM
Tikiman12
Tikiman12's Avatar
or you could buy z06 mufflers and then the 3" pipe will bolt right up to the muffler
Old 12-14-2011, 03:21 PM
Venom_C6
Venom_C6's Avatar
thanks guys. So the primary will bolt right up only thing that needs to be modify is the axelback? I have the NNP exhaust.
Old 12-14-2011, 05:15 PM
0MarylandSpeed
Former Vendor
MarylandSpeed's Avatar
They will fit fine except for where it connects to the axleback. Your stock axleback is is 2.5". The Z06 one is 3".
Old 12-14-2011, 05:19 PM
0Bobby @ LG Motorsports
Former Vendor
Bobby @ LG Motorsports's Avatar
Depends on the headers too..
If it is one of our Pro or Super Pro kits all you would need to do is change the front 02 extensions (Z06's are shorter), and the two pipes after the X to mate to your muffler system.
A 3" over the axle from a Z06/ZR1 will go as well, but getting around the automatic takes some work and you might have to dent the mufflers slightly.
Old 12-14-2011, 05:49 PM
Venom_C6
Venom_C6's Avatar
Thanks guys. I am looking at arh 1 7/8 with off road pipes
To Questions on headers
Quick Reply: Questions on headers
