Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-24-2011, 01:06 AM   #1
hippypink
Junior Member
Default Low beams randomly not working
First question: This is actually in regards to a Z06, but not sure if I should post here, or Z06 forum because it probably applies to C6's in general. Please move this to the correct forum if needed.
It's happened a couple times now where I am driving at night, stop the car for a minute (off), and then when I go to drive again, the headlights do not come on. I try the different settings (auto, on, etc..) to get the low beams on, but the only thing that I can get to work is the high beams.
When I park it, and go out the next day, they are working fine again.
Any ideas?
hippypink is offline   Reply With Quote
Old 11-24-2011, 04:50 AM   #2
Knob Jockey
CF Senior Member
St. Jude Donor '11-'12-'13-'14
Support Corvetteforum!
Knob Jockey's Avatar
In the fuse box in the engine compartment there is a Mini-relay for the Low Beams (#47).
You could test it by swapping it with Mini-relay #45 (Wipers on/off).
The Parking Lights use a different relay but if they are failing along with the Low Beams, then the problem could be the stalk switch.
Knob Jockey is offline   Reply With Quote
Old 11-24-2011, 11:04 AM   #3
torquetube
CF Senior Member
Any ideas?
You said that the low beams work again the next day. This sounds suspiciously like the same problem that several of us have experienced: the low beams quit working after the engine warms up.
If your problem is heat-related, the culprit is probably the backplane of the fusebox itself. A broken trace in circuit 1970, deep inside the assembly, goes open-circuit as it heats up. In my case it was dangerous, because the lamps would suddenly quit while driving home at night!
But first rule out the light switch itself. Cover up the light sensor on the dash or just wait until it's dark and twist the low-beam switch from Auto to Off. If the DIC says "Headlights Suggested" then you know the computer is receiving the signal from the switch.
If the switch is okay, you can isolate the problem pretty quickly with a multimeter. I'd start at the relay. Is it getting the signal? If not, go backwards toward the computer. If so, it's either the relay itself, or between the relay and the headlamps.
If your problem turns out to be the backplane, I strongly encourage you to report it to the NHTSA, because this is starting to look like a trend.
I describe it in more detail here: http://forums.corvetteforum.com/1577560168-post17.html
torquetube is offline   Reply With Quote
Old 11-26-2011, 04:38 PM   #4
hippypink
Junior Member
Default Will check it out
Wow! great info. Yes, so far it's only happened after i've driven the car a bit, so sounds like this is probably the problem. Now just have to wait till it happens again to test these.
Old 01-04-2012, 08:44 PM   #5
corvetteflyer
Junior Member
I have the same symptoms in my 2008 C6. Dealer wants $695 to replace the fuse box. Ouch! I will definitly report it to NHTSA as per TorqueTube's suggestion.
Cheers
corvetteflyer is offline   Reply With Quote
Old 07-03-2012, 04:25 AM   #6
H8VTEC
CF Senior Member
H8VTEC's Avatar
H8VTEC
Send a message via AIM to H8VTEC
I just started getting this problem too! Tonight I was driving then, poof no lights. High beams work, fogs work, etc. I let the car sit for a while and they work again and then poof gone.
H8VTEC is offline   Reply With Quote
Old 06-01-2013, 01:49 AM   #7
hymnatr
CF Senior Member
has anyone found out more about this? I'm getting this now on my 05.
hymnatr is offline   Reply With Quote
Old 06-01-2013, 09:43 AM   #8
truckplay
CF Senior Member
truckplay's Avatar
Send a message via AIM to truckplay
there is a TSB maybe a recall by now. the relays in the underhood fuse box over heat and folks complain that their lights shut off while driving.
__________________
Tom
truckplay is offline   Reply With Quote
Old 06-01-2013, 09:53 AM   #9
tucn26
CF Senior Member
tucn26's Avatar
i had the same problem bought a new complete under hood fuse box and fixed it.
tucn26 is offline   Reply With Quote
Reload this Page Low beams randomly not working
Tags
2006, beam, beamz, c4, c6, corvette, corvetteforum, day, fuse, headlights, low, lowbeam, problem, working, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
