LS2 Intake VS Fast Intake.
Tolero Apto Victum
Hay guys, I just picked up my new in the box Fast Intake today and needed to get it installed and dyno tuned. Luckily Geoff Cope at LMR "Late Model Racecraft" was able to help me out. They are located at 11755 West Little York Rd. STE 106, Houston, TX 77041 (713) 466-9900. http://latemodelracecraft.com/
The dyno pic below is a base line pull before the install of the Fast intake and my final pull with the Fast intake manifold installed.
The overall numbers are as follows:
RWHP increase by 28.29 hp.
RWTQ increase by 27.07 tq.
I do have a mild heads and cam setup. Also there is more info in my profile.
I would like to thank LMR and corvette forum member FloydSummerOf68, who helped me decide on this upgrade.
From His Profile
Year & Model
07 Z51 A6
Color
Black
Mods
Suspension: LG Motorsports Lowering Bolt Kit, GM T1 Sway Bars with Poly Bushings, GM T1 End Links, LG Sport Shocks.
Drivetrain: RPM A6 Differential - 2.56.
Braking: Performance AFX Motorsports Two Piece Slotted Rotors, Stainless Steel Brake Lines, Motul RBF 600.
Cam: (220/224, .581/.581, 113 LSA)
Biography
Engine: Callaway Honker Air Intake, Ported Throttle Body, Livernois Motorsports CNC Ported Stage 3 Heads, Katech Billet Belt Tensioner, Katech Coil Relocation Kit, Katech Cast Aluminum Valve Covers with Valve Cover Insert, 160 Degree Thermostat, ATI Super Harmonic Damper, FAST Precision Flow Fuel Injectors 33 LB/HR, Brisk Spark Plugs, MSD Spark Plug Wires, CompCams Custom Camshaft, Roller Lifters, Pushrods, Kooks Headers, Corsa High Flow Cats, Crossover Pipe, Sport Exhaust & Tune.
That is allot of money spent on the car , something seems off.
Year & Model
07 Z51 A6
Color
Black
Mods
Biography
OP I found the track gains to be higher than the dyno gains would indicate...the FAST is a GREAT mod for the ls2.
That car of yours is really rich...you'd get more power if you leaned it some, FYI. I personally run 12.5 and some guys go up to 12.9. But rich is safe, particularly if you are a road course maven.
From His Profile
Year & Model
07 Z51 A6
Color
Black
Mods
Biography
Year & Model
07 Z51 A6
Color
Black
Mods
Biography
He lists that the cam he's running is a 220/224 and the tune is obviously on the safe/rich side. I mean look, it's only running probably 11.0-11.5:1
A larger cam would net another 30-35rwhp with those heads, lean it out a bit and put him at an easy 460-470rwhp through an auto tranny.
All seems about right to me, but yes, it's a VERY mild build with that cam.
Well yeah, the peak numbers might appear a little light but I was merely commenting on his gains from the FAST intake, they are in line with what other internally modded LS2s have gotten and the results were quite strong.
Fast
HEY GERING--------THANKS for your post----that sure answers allot questions !! Your cam & build is almost identical of my 07--same before figures with my A6------I sent you a PM---Would be interesting to post this same set-up with a Peak Speed ported TB & Stock LS2 intake--anybody done that ???
Tolero Apto Victum
Sir, a while back I was told that maybe my stage 3 heads was a little to big for my mild cam. So maybe the stage 3 heads reduces the velocity, which in turn reduces my over all HP. I am not an engineer, so do not flame me to much.
Tolero Apto Victum
Well...to be precise, this verifies half of that theory! It doesn's speak to the ls3 side of the coin.
Tolero Apto Victum
Tolero Apto Victum
