LS3 Random Misfire
Old 11-06-2011, 11:37 AM
WhippledSilverado
WhippledSilverado's Avatar
Default LS3 Random Misfire
Have an 08 LS3 A6 with 14,000 miles that is throwing a random misfire code. It only does it at 100% throttle anywhere between 75-100+ mph. Seems to be on cyl 1 more so than any others. Switched plugs, wires, injectors around with other cyl's and still have the exact same problem. Any ideas? Not to often but it will finally throw a 0420 code. Never had the problem all year. It sat for over a month without being run and now have the problem out of the blue. Dumped injector cleaner in the tank also.
Old 11-06-2011, 03:42 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Valve spring, push-rod, compression???? The ONLY thing left. Tough one. If you have access to tuning software, do a cylinder balance test and see if that shows anything.
BC
Old 11-06-2011, 03:49 PM
SteveO326
SteveO326's Avatar
Did the battery die or was it disconnected while sitting?
Also if its throwing a 420, Catalytic Converters are covered by federal 8yr 80k, have it replaced...
Old 11-06-2011, 08:25 PM
WhippledSilverado
If it was something bent wouldnt it do it all the time, not just under full throttle. I can ease into throttle all the way up to redline and not have the problem, it is just under full throttle at high speeds. Just basically does it under alot of load.
Old 11-06-2011, 09:26 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
A blocked cat can cause miss fires under load.
Old 11-10-2011, 12:13 AM
Dirty Howie
Dirty Howie's Avatar
Can this damage a motor ??
DH
Old 11-10-2011, 04:15 PM
C7/Z06 Man
C7/Z06 Man's Avatar
DH
Yes
Old 11-10-2011, 04:33 PM
KB9GKC
KB9GKC's Avatar
Hello,
Replace the coil pack on that cylinder, sometimes they go intermittent.
Douglas in Green Bay
To LS3 Random Misfire
Quick Reply: LS3 Random Misfire
