Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-02-2011, 02:25 PM   #1
arfrieman
Junior Member
Default Can I replace electronic shocks with after market shocks?
I have a 2005 C6 with 80K miles and bad shocks. Can I replace the grossly expensive electronically controlled shocks with aftermarket shocks? I don't care about the 'Cruise/Sport' switch which never seemed to make a difference anyway, but I don't want to screw up the suspension.
Arnie
arfrieman is offline   Reply With Quote
Old 09-02-2011, 02:31 PM   #2
timd38
CF Senior Member
timd38's Avatar
Quote:
Arnie
Yes, you just need simulators for the plug so the car thinks you have the.
I think LG has them.
timd38 is online now   Reply With Quote
Old 09-02-2011, 02:35 PM   #3
arfrieman
Junior Member
Thanks, who's LG?
Old 09-02-2011, 02:42 PM   #4
arfrieman
Junior Member
Never mind, found them.
Old 09-04-2011, 03:27 AM   #5
HOXXOH
CF Senior Member
HOXXOH's Avatar
How did you determine that you have bad shocks?
So far, only a couple of people on this forum have reported problems with just one shock.
I have 92K on my F55 equipped '08 and no shock issues at all.
HOXXOH is offline   Reply With Quote
Old 09-04-2011, 09:18 AM   #6
theVcar
CF Senior Member
St. Jude Donor '08
theVcar's Avatar
Do shocks wear out, or can they loose some of there performance? I have 87k on an 06 Z51 and thought they may be loosing their bite just from all the hard abuse. LMK
theVcar is offline   Reply With Quote
Old 09-04-2011, 02:06 PM   #7
Gene Culley
Platinum Supporting Vendor
Gene Culley's Avatar
Shocks are certainly going to lose their luster after 50,000 miles. Over that mileage they're not going to be performing or doing the job they were when you bought it.
__________________
Founder of GM Parts House
Home Of The Corvette Parts And GM Parts Specialist
Please Visit GM Parts House Online or Call 484.949.2099.
Gene Culley is offline   Reply With Quote
Old 09-06-2011, 03:09 PM   #8
arfrieman
Junior Member
I started hearing some noises in the suspension and the car seemed to be scraping the front spoiler more than usual. So while the car was in the shop for an AC problem I asked them to look at the shocks and the mechanic said all four were leaking.
Old 09-06-2011, 03:59 PM   #9
BEZ06
Formerly beezeye
Support Corvetteforum!
BEZ06's Avatar
I would not take that mechanic's dagnosis as gospel - they love to sell parts that they think have finite life limits, are quick to swap out, and make them some fast money.
Was this at a large Chevy dealership with a lot of MSRC/F55 experience???
If not, I'd completely disregard his comments about leaks. They wouldn't even know what they're dealing with if the mechanic isn't a GM Tech trained on the F55/MSRC.
You can swap to regular valved shocks, but the MSRC is a really nice system and there a very, very few credible reports here on the forum of failures of the magnetorheological shocks failing.
Instead of the LG simulators, I'd recommend just going to a dealer and get them to de-program the F55 with their Tech 2.
Just MHO, YMMV!!
Bob
__________________
BEZ06 is offline   Reply With Quote
Old 09-06-2011, 04:02 PM   #10
99c54me
CF Senior Member
Arnie, I suggest you get another opinion. A small amount of oil on the shock is often more than enough for some to say they need replacing. But the truth is a small amount of oil on the shock is not indicative of your shocks needing replacement. The mag ride shocks work differently than a typical shock.. don't get suckered.
If you are scraping than maybe the ride height simply needs adjusting. After so many years/miles the springs do sag a bit and can easily be adjusted up to spec height.
99c54me is offline   Reply With Quote
Old 09-09-2011, 02:19 PM   #11
billsee
CF Senior Member
Default F55 shock failure
Arnie
I have F55 shocks on 2007 MN6. The ride was going to hell at 15,000 miles. Took it to the dealer and mechanic said they were leaking and ordered replacements. GM came back a week later and said "leakage is normal" and refused to replace them.
The ride has continued to degrade, it rides like a truck. I suspect the computer has it on full-hard. As bad as my 2005 Z51. Noises come from the back suspension from even little ridges at the edges of driveways. two dealers looked at it and can't find anything wrong (NOT sway bar links). Shocks?
Last week, while on a cross-country drive, a "SERVICE RIDE CONTROL" message came on. I'm going to make one more dealer pass at this but can guarantee I'm NOT going to pay double the retain price of the F55 option to replace them.
OK, I vented. Do you have any good ideas what you're going to do next?
Don't want stiff Z51 again.
Regards - Billsee
billsee is offline   Reply With Quote
Reload this Page Can I replace electronic shocks with after market shocks?
Tags
02, 2006, adjustment, aftermarket, aftermarwket, bad, c5, c6, corvette, electronic, price, ride, shock, shocks, suspension, vett, works
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
