08 A6, Park Lockout
08 A6, Park Lockout
I can't move the shift lever into the Park position. I can move it easily between Drive and Neutral. By jiggling and pushing and shovin on the lever I can get it into Reverse. Also, I can't get it into Sport. I can start the car in Neutral, something I never tried before.
Can anyone help? I did do a search function and there were postings about people whose trannies were locked in Park, but couldn't find any where people were locked out of Park.
I'm probably not going accurately describe what happened leading up to this. After I let a friend drive around the neighborhood, we arrived back on my house and he stopped the car. I don't remember if he placed the shifter in Park. I wanted to show him how the Heads Up Display indicated the paddle shifter gear selection. I attempt to pull the shifter (I was in the passenger seat) into S, and as I recall it wouldn't go in. Anyhow, don't remember, but I think before I could get it into S, he may have turned the engine off. Anyhow upon restarting the car in neutral, I then discovered that I was stuck in N or D. Initially I could not get it in R but after turning off the engine, and trying a couple of hours later I could, with trouble, get it into R. Still locked out of P and S.
Thanks. Any insight will be appreciated.
In most cases where the A6 shifter only works in N and D the shifter is broken and needs to be replaced.
Here's just one example, the OP reported situation similar to yours, I told him the shifter is broken in post #2, he finally confirms it in post #20. Good luck.
http://forums.corvetteforum.com/c6-t...r-neutral.html
Actually, ....I was wishing someone would tell me to disconnect the battery for a few hours, reconnect it to reboot the computers, and everything would be OK!!!!
Nope, not out of warranty. It's a November 2008 car and I think my three year warranty will cover it. Also I bought a two year extention warranty.
My now concern is getting it repaired with no damage. The dealer I bought it from doesn't do that many Corvettes, mostly other Chevrolet products. I'm going to investigate taking it to a dealer that has a lot of other Corvette traffic.
I restored my 68 and went to a lot of expense to make the little things correct...even things you can't see. Similarly with my 70 which is still in "process." My 68 and the 70, as far as it exists today, have factory stock mint interiors. I don't want the repair to my 08 leave any blemish in the car. I belong to a Corvette Club and I'll try to find a dealer that won't damage the car.
For sure, if the car were out of warranty, I would try to repair it myself. Actually, since it is in warranty I don't want to try to repair it myself, since if I did make something that looked liked a mistake, the warranty would be invalid.
My philosophy....general rule, is that if someone has assembled something, I can disassemble it and reassemble it. For sure, it won't necessarily be straightforward. I may need special tools and special knowledge. Also, I recognize that I may not be able to repair or "fix" something the first time. I'm prepared to try many times to make a repair.
It may be as simple as the gear shift ****. Another forum member had this happen to his car and they replaced his entire shifter. After it was fixed a buddy of his messed around with the broken shifter and found a plastic piece broken in the ****. If the piece is broken,you remove the **** (which is a PIA until you learn how) and move the shifter into park. You can pull the top cap off of **** and then the front piece exposing where the piece that breaks is. If you want I take pictures of a **** pulled apart and show you the exposed areas. But if you are under warranty why mess with it?
How do I know this? Well I had my **** off for some time because it was such a PIA and I was working on different projects which required removal of console.
