Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-29-2011, 12:27 AM   #1
elitebomberX
CF Senior Member
elitebomberX's Avatar
Send a message via AIM to elitebomberX
Default Oil pressure gauge dropping to 0 and then going back up
A couple months ago, while I was driving home, I heard a *ding* and looked down and saw a low oil pressure warning...I then looked at my gauge and saw it read 0. I immediately cut-off my engine and got off the road.
I checked the oil level which was fine and when I started it again, it read the normal idle pressure. I just figured it was a fluke and didn't think much of it. I went months with no issues.
Yesterday it happened to me again once, but I didn't notice it right away because I had music playing (a little loudly). It caught my eye and I saw it was at 0 and then it jumped back up before I could shut the motor off.
Today it has happened to me 2 or 3 times. It drops to either 0 or a very low pressure reading and then jumps back up.
Does this sound like a bad sending unit/oil pressure sensor or possible failure of the oil pump? The car is a base 2007 with ~48k miles.
Any help is appreciated!
EDIT:
Quote:
Originally Posted by elitebomberX View Post
It was in fact the oil pressure sending unit that had malfunctioned. Got a new one put in at the dealership and everything is peachy!
Thanks everyone for the insight.
elitebomberX is offline   Reply With Quote
Old 07-29-2011, 03:13 AM   #2
LS1LT1
CF Senior Member
LS1LT1's Avatar
Send a message via AIM to LS1LT1
Yes, that's exactly what it sounds like.
LS1LT1 is offline   Reply With Quote
Old 07-29-2011, 06:24 AM   #3
taken19
Track junky
taken19's Avatar
Quote:
If your oil pump was dying you would have consistently lower readings, not zero and back to normal. The oil pump is a gear driven pump and wouldn't display that kind of behavior if it failed.
taken19 is offline   Reply With Quote
Old 07-29-2011, 07:41 AM   #4
REVAK
CF Senior Member
REVAK's Avatar
Sounds like a bad sending unit. Search this forum for the trick method for replacing the sender without removing the intake manifold. If mine fails , I think I will try this method. [ cut through the cowl ]
REVAK is offline   Reply With Quote
Old 07-29-2011, 01:08 PM   #5
Pack Leader
CF Senior Member
Pack Leader's Avatar
Quote:
Not so..... I had my pump replaced under warranty for the exact condition.
PIP4158C: Low Oil Pressure Due To Seized Oil Pressure Relief Valve - (Dec 29, 2009)
Subject: Low Oil Pump Pressure due to Seized Oil Pressure Relief Valve
Models: 2008-2009 Buick Lacrosse, Allure (Canada Only)
2007-2010 Cadillac CTS-V, Escalade
2007-2010 Chevrolet Avalanche, Corvette, Silverado, Suburban, Tahoe
2007-2008 Chevrolet Monte Carlo SS
2007-2009 Chevrolet Impala SS, Trail Blazer
2009-2010 Chevrolet Colorado
2010 Chevrolet Camaro
2007-2010 GMC Envoy, Sierra, Yukon
2009-2010 GMC Canyon
2008-2010 Hummer H2
2008-2010 H3 Alpha
2008 Pontiac Grand Prix GXP
2008-2010 Pontiac G8 GT
2007-2009 Saab 97x
with the Following Aluminum V8 Engine RPOs:
L76, L77, L92, L94, L99, L9H, LC9, LH6, LH8, LH9, LS2, LS3, LS4, LS7, LS9, LSA, LZ1
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may complain of low oil pressure, no oil pressure, and/or engine noise, which may be the result of a sticking oil pump pressure relief valve. In some instances, this may occur intermittently if the valve frees up when the engine cools down.
Recommendation/Instructions:
If SI diagnosis isolates low mechanical oil pressure at the oil filter housing and oil pressure sensor, replace the oil pump, flush the oil cooler lines (if equipped), clean the inside of the oil pan, change the oil and filter, and re-evaluate the concern.
Notice: If an engine noise is noticed after replacing the oil pump, follow the SI diagnosis and repair the engine as necessary.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Pack Leader is offline   Reply With Quote
Old 07-29-2011, 03:10 PM   #6
taken19
Track junky
taken19's Avatar
2008-2010 Hummer H2
2008-2010 H3 Alpha
2007-2009 Saab 97x
Condition/Concern:
I stand corrected.
Old 07-29-2011, 06:31 PM   #7
Pack Leader
CF Senior Member
Should have added that the technician Thomas, at Vara Chevrolet in San Antonio did an excellent job. Have had no further issues since the pump was replaced a little over 6 months ago. My car was flatbedded to the dealership in the morning and I had my car back by COB next day. Car was washed and the paper floor mat protectors were still in the car when I picked it up.
Old 07-30-2011, 11:52 PM   #8
MarkRx
CF Senior Member
MarkRx's Avatar
this explains why all the LS7's are blowing up lol. i used to like dealers washing my car when it went in for service. now i'll let someone else have the swirl marks.
MarkRx is offline   Reply With Quote
Old 07-31-2011, 07:20 AM   #9
elitebomberX
CF Senior Member
Thanks for the replies guys. It happened to me once today. It dropped to 0 then I gave it some gas and it shot right back up. The possible failure of the oil pump has me concerned. I'll take it in to a dealership to be safe.
Old 07-31-2011, 07:58 AM   #10
elitebomberX
CF Senior Member
If the oil pressure was really at 0 for a couple of seconds, wouldn't you expect the temperature of the engine to raise rapidly?
Old 07-31-2011, 08:45 PM   #11
Red86Cfour
CF Senior Member
Red86Cfour's Avatar
I might expect to see the oil temp rise (if the pressure came back and there was oil flow again). What I would NOT want to see is bearing material on the bottom of the oil pan or in the filter. If the oil pressure stayed at zero long enough kiss most of the rotating parts in the engine good bye. The amount of time it takes for that to happen isn't long enough to heat up the coolant.
Red86Cfour is offline   Reply With Quote
Old 07-31-2011, 09:07 PM   #12
saplumr
CF Senior Member
Support Corvetteforum!
saplumr's Avatar
Probably nothing more than the connection at the oil pressure sending unit. Mine would go XXX periodically and bounce right back up. I knew it wasn't the oil pump due to the fact it could happen for at least 20-30 seconds and no engine seize.
saplumr is offline   Reply With Quote
Old 07-31-2011, 10:44 PM   #13
elitebomberX
CF Senior Member
Quote:
Yea, that's what I'm thinking or hoping at least. I know it was probably at 0 for 10-20 seconds before I noticed it one time.
I just wish I had some free time to take care of this right away. I might try to bounce from work tomorrow and get the dealership to look at it. Or I could wait until I get back from vacation and do it myself. Decisions decisions...
Old 10-01-2011, 11:31 PM   #14
schizcat
CF Senior Member
schizcat's Avatar
curious, did you ever get this taken care of? seems to be a problem around Austin
schizcat is offline   Reply With Quote
Old 06-02-2012, 10:45 PM   #15
elitebomberX
CF Senior Member
Quote:
I didn't because the problem just went away after I changed my oil... until today (months and months later).
It seems as soon as the weather heated up, the problem came back. But now, it's just stuck at 0. No bouncing at all. I tried changing the oil today to see if that would make a difference and it didn't. I am taking the car to the dealership tomorrow to be safe. I will post what they find.
Old 06-07-2012, 02:06 PM   #16
elitebomberX
CF Senior Member
Old 08-17-2012, 10:05 PM   #17
Vital Velocity
CF Senior Member
St. Jude Donor '11
Vital Velocity's Avatar
Send a message via AIM to Vital Velocity
I was hoping we would get away with the same thing as I had the same symptoms....changed out the pressure switch today, still at 0
Vital Velocity is offline   Reply With Quote
Reload this Page Oil pressure gauge dropping to 0 and then going back up
Tags
2005, 2010, add, avalanche, back, cadillac, chevy, cts, dropping, drops, gauge, guage, jumps, oil, pressure, sits
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
0 PSI Oil Guage Zoidman C5 Tech 11 08-20-2014 07:26 PM
Update on low oil pressure on my '86!! Please Read! tnz5106 C4 Tech/Performance 27 07-29-2014 05:43 PM
Oil pressure gauge problem? 96_Corvette C4 General Discussion 1 05-22-2014 01:46 PM
Oil pressure Problems pharestutt C5 Tech 6 03-03-2014 08:34 AM
Oil Pressure Drop in straight line acceleration Memphomaniac C6 Z06 Discussion 15 06-06-2013 08:47 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
