SNL Performance Cam Install Special!
Received 2,044 Likes
Guys/Gals,
We're getting some things cleared out of the shop and decided to do a camshaft install special!
Let's get to it, here's what you'll get -
- Any SNL Performance/Texas Speed Camshaft or a custom grind based on your engine/goals
- PRC .650 Dual Valve Springs
- Chromoly Hardened Pushrods
- All Necessary GM Gaskets and Crank Bolt
- Mobil 1 Oil Change w/ACDelco Oil Filter and Dexcool Coolant
- Tax
- Professional Installation
- Tuning by one of the best tuners out there on our Dynocom that includes a baseline and final numbers
omg - 20 Mi NE St Louis, MO is how far from Fort Worth?
Curious - Is tuning done via hacking the C6 ECU; mine is a 2006 Z51 Vert? (C6 Newbe but I know how and have equipment and software to hack Suzuki ECU's)
Believe it's ~8 hrs, but we can not be held responsible for any tickets Seriously though, we use HP Tuners and a DynoCom to tune.
just checked ballpark est for one way..
Total Travel Estimate: 11 hours 14 minutes / 725.24 miles
Thanks for clarifying about non-reimbursement for tickets - could be a factor for me at 24 hours behind wheel!
TY for info on Tuning!!!!!! I have driven 10+ hours numerous times RT for professional tuning on my favorite Suzuki Motorcycles!
seriously considering this too. You suggested the V2 for me, whats the next one up and how does it differ from the V2? Would it be good for DD and how much more power does it make over the V2? Thanks.
I believe you had an auto and the V2 is the only cam that will work with the factory stall which is why I suggested it and wil great a great DD with perfect street manners being barely detectable.
Results of our V4 cam+headers in an Automatic LS3 Camaro
What would be your recommendation for a choppy idle cam in a standard C6 manual be. I am looking for street-able power; basically jumping from streetlight to streetlight and powering through the back roads in the mountains. Other upgrades I plan to do during the project are long tubes, full 3 inch exhaust and air intake modifications.
It's a 05 LS2
It's a 05 LS2
It's a 05 LS2
It's a 05 LS2
