C6 Automatic shift knob
Old 07-20-2011, 12:01 PM
Canis lupus
Canis lupus's Avatar
Default C6 Automatic shift ****
Got into my car last evening... went to put the car into gear and two pieces of plastic came off the shifter ****... the silver piece on the top and the plastic piece that you depress to move the shifter.
I seemed to have snapped it back together and then called the dealer as it is on warranty.
My question.... has this happened to anyone else here?
It's pathetic that a car that cost this much can fall apart from simple use
Old 07-20-2011, 01:32 PM
mrgillies
mrgillies's Avatar
Mine rattles at times as well....
Old 07-20-2011, 02:36 PM
Gering
Tolero Apto Victum
Support Corvetteforum!
Gering's Avatar
The silver plastic piece that you depress to get in to gear broke on mine a few months ago. Had to install a new shifter. 07 Z51 A6.
Old 07-20-2011, 10:29 PM
DSOMC6
DSOMC6's Avatar
Find a GM parts wholesaler if you drive your car daily and plan to keep your car beyond the warranty period. Have a second car for the times that the part you need takes a week to get to you cuz no friggen dealer within 2hrs has the part, bolt or gasket. /thread
Old 07-20-2011, 11:24 PM
Timothy Barth
Timothy Barth's Avatar
It is amazing the little things that happen to these cars.I had the accelerator pedal come off of mine and putting it back on would make the pope cuss. Very tricky.
To C6 Automatic shift knob
Quick Reply: C6 Automatic shift knob
