Bumper Wings Won't stay down
Old 04-07-2013, 11:33 PM
FireRoc
FireRoc's Avatar
Originally Posted by ncvette_1FUNRIDE
You could take a wood chisel and carefully chop off the part that shows BUT it is only pressed into the hole. You should be able to get a small screwdriver (flat head) behind that part and just pry it out.
I would not pry it out as it could enlarge the hole in the urethane. It's much better to cut it out. A wood chiesel should work well.
Old 04-07-2013, 11:36 PM
FireRoc
FireRoc's Avatar
When I replace one on my car, it still would not stay down. So we wound up putting a s all thin washer behind so the ramp portion protruded more. That worked like a charm.
Old 04-08-2013, 03:36 AM
C6topless
C6topless's Avatar
Originally Posted by Caddy Man
Hi guys, I have a question. If you refer to the last picture in post #5, that is the part that is broken on my car. I understand how to put the new part in, but how do I go about taking the broken part out? What is the best method?
I know in that post it says to "snip" off the flat piece. Well how is that supposed to work since the flat piece is flush against the fender?
Thanks!
I used an one sided razor
Old 05-29-2013, 10:11 AM
phylrick
Support Corvetteforum!
phylrick's Avatar
Yep this is the problem.......great post......will I have to remove the whole front piece to install this????? Have not attempted this yet.....I know I will some time for headlight maintenance but have avoided it till now.
Old 05-29-2013, 08:56 PM
C6topless
C6topless's Avatar
I did not remove the whole front piece.. All I did was remove the inner lip bolts... I think there are 3 or 4 ... Once they are off, pry the front piece off .. That will expose the clips..
Old 05-30-2013, 09:41 AM
phylrick
phylrick's Avatar
Many Thanks.....I see what you mean. Just need to get parts now.
Old 05-30-2013, 10:26 AM
C6topless
C6topless's Avatar
Don't go to your local dealership as they will try and sell you a dozen ..and tell you that no one sells them individually, which is false.
I bought mine thru a vendor here ...
Old 06-09-2013, 06:35 PM
brucemc
brucemc's Avatar
I bought mine at a local Chevrolet dealership. (4) just so that I'd have spares.
Old 06-09-2013, 07:21 PM
EuroRod
EuroRod's Avatar
I just replaced my clips yesterday! I also replaced the small wedge shaped clip at the same time. Took all of 5 minutes per side and made all the difference in the world.
Old 06-06-2014, 01:52 PM
vettegator005
vettegator005's Avatar
[QUOTE=Motorhead-47;1578028867] Found it in an earlier post...
and the small ramped fastener is
Are these the same clips I would use on an 07 base coupe because gene culleys homepage says these are for the grandsport or z06. Also how much would it cost for the dealer to do it for me?
topmop1 (05-15-2018)
Old 06-06-2014, 02:31 PM
C6topless
C6topless's Avatar
[QUOTE=vettegator005;1587072212]
[/QUOT
Those are the one's I used for my 2007 vert. As for dealer costs ... although it is a fairly simple and quick job, I was given an estimate of $110 dolalrs to do what I did under $10.
Old 07-18-2014, 11:42 PM
JaimeVrod
JaimeVrod's Avatar
Great write up. I ordered my clips from GM Parts House and there were inexpensive. They arrived today. This was an easy fix and took only 10 minutes for one side and I tend to be overly meticulous so you could probably do it in 5 minutes.
Old 07-19-2014, 12:50 AM
  #33
ronsblackc6
Cruising
ronsblackc6's Avatar
Just replaced the retainer (clip) 11561329 at the dealership this week. Cost was $19.46 and if they screw it up, they fix it.
Old 05-01-2015, 11:38 PM
  #34
rafael707
rafael707's Avatar
Hey guys I'm in the process of changing both the clips and fasteners, but I'm having a hard time looking for the part numbers. Which ones would it be?
http://www.cultragfactoryparts.com/a...-scat?mobile=0
would the stealership be an option to buy all 4 fastener's or is this site better?
Old 05-01-2015, 11:53 PM
  #35
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
Either one will do. they have the same parts, but the dealership may be a tad more expensive, but offset by the extra shipping cost of Cultrag or GM parts direct.
The dealer may want to sell you a package of 10 rather than individuals. Never hurts to ask if he can sell individually.
Just put in the part # in the space at the top of Cultag Performance page, and it will come up with the part name, price etc.
Part #- 11561329 - Genuine GM (ROCKER MOLDING RETAINER) $4.74 each
Part #-11609871 - Genuine GM (BUMPER COVER RETAINER) $0.97 each
Old 05-02-2015, 12:13 AM
  #36
rafael707
rafael707's Avatar
I appreciate the info, thank you
Old 05-02-2015, 03:02 PM
  #37
CMY SIX
CMY SIX's Avatar
Originally Posted by Danspeed1
I had a body shop recently replace them. Hopefully they were replaced with new ones. Any bumper adhesive I can use on this thing to keep them down?
DG
take it back to the bodyshop and make them do it over, or do you just pay for nothing?
To Bumper Wings Won't stay down
Old 08-16-2015, 07:03 PM
  #38
[Cerberus]
[Cerberus]'s Avatar
I have replaced all the clips and it still pops up. The only Way I can see to "fix" it is a whole new front clip or two 3" deck screws down through this pos.
It is such a cheaply built pos car for what it is supposed to be.
Old 08-16-2015, 11:12 PM
  #39
ncvette_1FUNRIDE
ncvette_1FUNRIDE's Avatar
2015 C6 of the Year Finalist
The trick to getting those clips to work is getting the gap where the font fenders and the bumper meet (near the headlights and hood) to as small as possible. If the gap is too wide the clips slip out of the indentation and they will never hold the bumper edges very well.
I had to adjust my fenders just slightly to close the gap a little and that helped a lot.
Old 01-04-2016, 08:13 AM
  #40
scotzz
scotzz's Avatar
Default Part Numbers for 2005?
LV2TOUR...........I went to the Culley site and it shows these part numbers for 2006 and newer............do you know what the part numbers are for a 2005?
Quick Reply: Bumper Wings Won't stay down
