Windshield Wipers Won't Parf
I got caught in a little rain today in my '07 ZO6, something I try to avoid. I had to use the wipers and noticed when I turned them off with the stalk they do not park. They are up a couple of inches above the park position - they look bad.
I have looked over the WSW section in the Service Manual which isn't much help to me. It looks like I need to check the the 10A WIPER DWELL fuse, but I'm unable to locate it in the under hood fuse block.
Any ideas?
TIA,
Pete
Any ideas?
TIA,
Pete
Just had the same thing happen to me. Seems that the park pin is stuck in the wrong position. I'm trying to fix it right now but not having much luck.
There's a step by step guide here: http://www.digitalcorvettes.com/foru...d.php?t=121213
Hope this helps. Btw the title of your post is misspelled :P
Thanks Stealth. I checked the link you provided, and decided that I would have the work done by the local Chev. dealer, since I still have an extended warranty. You were right, it was the wiper motor. Theere is no indication of labor involved, but I'd guess at least 2 hours, plus ~$100 for the motor.
BTW, that was a typo, not a misspelling, although the end result is the same. And a title cannot be edited
Pete
Pete
