Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-08-2011, 02:54 PM   #1
USA1C5
CF Senior Member
Support Corvetteforum!
USA1C5's Avatar
Default Check Engine Light
I know there has been a lot of discussion about The Check Engine Light. I've even done some search here on it. I guess the most common reason would be The Gas Cap it seems. Anybody got or had The Check Engine Light come on and what was the problem? I know there are many reasons for The Check Engine Light but I'm trying to find out the most common reasons. What say you. I'm gong to start this thread in the C6 Z06 Corvette also.
__________________
USA1 C5 USA1 Z06
USA1C5 is offline   Reply With Quote
Old 05-08-2011, 03:07 PM   #2
Z11409
CF Senior Member
What codes are showing?
Z11409 is offline   Reply With Quote
Old 05-08-2011, 03:16 PM   #3
USA1C5
CF Senior Member
USA1C5's Avatar
Quote:
I haven't checked the codes yet. Light just showed up last night. Trying to find out all I can about the Check Engine Light for now.
__________________
USA1 C5 USA1 Z06
Old 05-08-2011, 03:36 PM   #4
flor
Junior Member
Hello i had the CEL about two years ago. It gave codes P0172 and P0175. I replaced the gas cap with no luck. Placed a new air mass meter, this solved the problem for a month or so. But when it showed up again it looked like it came up after bumps in the road. I secured the connector to the air mass meter and wiring with a tire wrap to the AMM housing so it couldn't move anymore and the CEL hasn't shown up since. That was about one and a half year ago.
flor is offline   Reply With Quote
Old 05-08-2011, 03:43 PM   #5
shado
CF Senior Member
shado's Avatar
There is no "most common" reason the CEL light comes on. NEVER assume it's one code or another. ALWAYS get it checked.
shado is offline   Reply With Quote
Old 05-08-2011, 03:55 PM   #6
USA1C5
CF Senior Member
USA1C5's Avatar
Quote:
I agree with get it checked but, there has to be a most common (happens more often than any other) reason it happens. Even the owners manual don't treat the Check Engine Light on steady as too serious.
__________________
USA1 C5 USA1 Z06
Old 05-08-2011, 04:58 PM   #7
Mez
CF Senior Member
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
There are too many things that can trip the CEL. Never assume. Its too easy to check.
Mez is offline   Reply With Quote
Old 05-08-2011, 06:05 PM   #8
FireRoc
CF Senior Member
FireRoc's Avatar
There are something like 160+ variables that OBII monitors. As such, there are a lot of different things that can cause the CEL to come on. As already said, the best thing you can do is read the codes, then there is no guess work. You can buy an OBII code reader for under $100 this days.....I always carry one in my car.
FireRoc is offline   Reply With Quote
Old 05-08-2011, 06:21 PM   #9
USA1C5
CF Senior Member
USA1C5's Avatar
Yes, I do need a code reader. I have been shopping around on the Internet today and find many models from about $30 on up. Who makes the best code reader for the money and then who makes just the best?
__________________
USA1 C5 USA1 Z06
Old 05-09-2011, 04:50 AM   #10
flor
Junior Member
Just buy a obd2 scanner on ebay This will tell you the code and this link will show the possible codes, it's obvious there is not one common fault to set off the cel.
en.wikipedia.org/wiki/OBD-II_PIDs
Old 05-09-2011, 06:44 AM   #11
MARSC6
CF Senior Member
MARSC6's Avatar
Several years ago I had a CEL because of the gas cap. Been fine since.
If your looking for a scanner Amazon is an excellent source. I wouldn't really say one particular scanner is better then the rest. You just need to decide what features you want. I went with a basic scanner that reads, clears codes, and shows completed emissions tests. I'm also playing around with a Bluetooth transmitter that plugs into the OBDII port. With that I can use my Android phone to take care of codes as well as monitor other data.
MARSC6 is offline   Reply With Quote
Old 05-09-2011, 10:29 AM   #12
USA1C5
CF Senior Member
USA1C5's Avatar
I just ordered an ob2 scanner on Amazon so I can actually see what it is.
But, it's not obvious to me that there is not one common fault to set off the check engine light. I know there are many, many things that can trigger the check engine light. However if one was to list all the faults and the number of times that fault has been triggered there has to be one that is triggered the most. There might be a close second etc., but one fault has to win or do you think there would be a tie for the lead fault?
My new obd2 reader should be here in 2 days and then I'll know which one is at the top of my list anyway.
__________________
USA1 C5 USA1 Z06
Old 05-09-2011, 10:33 AM   #13
USA1C5
CF Senior Member
USA1C5's Avatar
Yes, I've had the gas cap trigger the check engine light on another vehicle (non-Vette) in the past. My guess is that's probably the top fault but that's just a guess on my part.
I went ahead an ordered an Equus 3130 Innova Diagnostic Code Scanner on Amazon last night. Should be here in a couple days.
__________________
USA1 C5 USA1 Z06
Old 05-09-2011, 10:50 AM   #14
SpinMonster
SpinMonster's Avatar
Send a message via AIM to SpinMonster
I never had a check engine light. I think no light is the most common.
SpinMonster is offline   Reply With Quote
Old 05-09-2011, 10:59 AM   #15
USA1C5
CF Senior Member
USA1C5's Avatar
Quote:
__________________
USA1 C5 USA1 Z06
Old 05-09-2011, 12:40 PM   #16
shado
CF Senior Member
shado's Avatar
Just because, let's say a gas cap light, is the most common, that doesn't mean that's what YOUR light is from. If you're checking it anyway, the most common doesn't really matter. Research just for the sake of research?
Old 05-09-2011, 12:54 PM   #17
vette902
CF Member
so what is deal when a light comes on and then goes off and has not been back on since?
vette902 is offline   Reply With Quote
Old 05-09-2011, 01:01 PM   #18
USA1C5
CF Senior Member
USA1C5's Avatar
I agree, but no body said my problem would be the most common. I have a scanner on the way to find out actual problem. I was just curious about what the most common would be. Why are you flying off the handle because I was curious. I would still like to know what the most common problem is. I started this thread to research what the most common problem was, not to debate if it mattered or not. Just curious!
__________________
USA1 C5 USA1 Z06
Old 05-09-2011, 02:07 PM   #19
shado
CF Senior Member
shado's Avatar
Quote:
Haha...how am I flying off the handle??? I was just curious why you were so insistent on finding the most common cause. Most common for what? Stock? Tune? Headers w/cats? Headers w/o cats? CAI? H/C? S/C? Nitrous? 89 oct? Any one of these could set off codes for all sorts of things. I'm sure i'm just restating the obvious now though. I'd just hate to see someone assume it's one particular code because it always pops up and have it actually be something more serious and cause damage. (I've seen it before) but that's your business I guess.
Good luck with your search
Old 05-09-2011, 02:08 PM   #20
USA1C5
CF Senior Member
USA1C5's Avatar
Why is it that no matter what thread is started there is always someone that has to be argumentative on something. There is always somebody.
__________________
USA1 C5 USA1 Z06
Reload this Page Check Engine Light
Tags
2006, c6, cel, check, code, corvette, engine, light, list, ls2, motor, raining, reader, resetting, things
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
