C6 Z06 MSD 2 Step
C6 Z06 MSD 2 Step
Okay I'm totally brain farting right now. I have the MSD 2 step installed into my 2006 c6 z06 . ( red led activated) Now I have it set to hot on the CCP to engaged with the clutch pedal. So I'm driving it and the 2 step only works when the clutch is not engaged. Any install input would be great.
tizzee11 (11-18-2017)
NVM figured it out !!!!! these hot summer nights make me brain dead . If anyone is interested in doing it just connect to the PK /WH wire on circuit no. 1035
( it acts as a momentary switch.)
On when car is off and off when car is on. but won't engage unless you have your clutch all the way down.
Enjoy
Enjoy
I’m about to install my MSD 2 step and I want it to activate when my clutch is all the way to the floor. Just making sure I’m on the same page as you, I connect the white/blue wire from the msd to the pk/wh wire on the clutch pedal and that’s when It will engage, right?
Do you have a pic from your car where you hooked up the wire on your clutch?
Enjoy
Enjoy
For anyone that finds this thread - I just finished up the install of my MSD 2 step.
On my 2005 C6 Corvette - I ran the blue/white wire from the MSD box to the Purple/White wire coming out of Pin B on the lower Clutch Position Switch.
The wiring diagram for LSX Revival has it as a pink/white wire - but on my 2005 it was Purple/White.
I have tested the 2 step - and it works when you push the clutch pedal in.
You can either unplug the 2 step box - or add in a switch to turn off/not complete the circuit to disable the 2 step for when you don't need it.
