Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-23-2011, 07:00 AM   #1
Dean Prevolos
CF Member
Dean Prevolos's Avatar
Default 05 Hood Struts won't stay open
I went to check my fluids yesterday and my hood struts won't stay in the upright position to keep the hood open. Has anyone ever had that happen with no incident? Is this covered under warranty or do I have to replace? Any advise is appreciated. Thanks,Dean.
Dean Prevolos is offline   Reply With Quote
Old 03-23-2011, 07:29 AM   #2
GOLD72
CF Senior Member
GOLD72's Avatar
Quote:
My 06Z06 did that back in December after about 4-1/2 years. One of the struts had lost its gas charge. Very unlikely that both struts have failed. They are kind of pricey. This should be a DIY. The same GM part number covers either side. You could buy one and guess a side that's bad and see if you are correct. If not, take the one you removed and put it on the other side. Of course, if one has failed, the second could fail sooner or later so you can rationalize replacing both at the same time and be done with it.
At each end of the strut, there is a band clip that has to be at least partially removed by prying with a small flat blade screwdriver. Tug on the strut end at the same time. The strut attaches to a small ball on the hood bracket and the band clip retains the strut to the ball at each end. The new strut just snaps in place. I used a little lube spray at each end to ease the new strut snapping back in place. It is really a simple R/R.
__________________
GOLD72
1972 WB Coupe L48/TH400 - Sold
2001 QS Z06 - Sold
2006 VY Z06 - NCM Delivery - Sold
2007 MR Vert - NCM Delivery & Wife's Garage Queen
2010 Vanilla Latte CTS 3.6L Sport Wagon - Wife's DD
2011 AW ZR1 - NCM Delivery & Daily Beater
GOLD72 is offline   Reply With Quote
Old 03-23-2011, 08:47 AM   #3
Andy 53
CF Senior Member
Andy 53's Avatar
I had to replace both of mine last year on a 2005. I noticed that the hood wouldn't stay up with a slight breeze.
Have a helper with you to hold the hood steady and take the pressure off the strut while you change each one. It only takes about 2 minutes to change each one.
So simple a cave man could do it!!
Andy
Andy 53 is offline   Reply With Quote
Old 03-23-2011, 08:45 PM   #4
schilitj
CF Senior Member
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
Support Corvetteforum!
schilitj's Avatar
just replaced my hood and rear hatch struts. Very easy. Agree that it is much easier with two people.
schilitj is offline   Reply With Quote
Old 03-23-2011, 09:06 PM   #5
NYC6
CF Senior Member
NYC6's Avatar
Do you have an extended warranty? If not, you gotta eat it.
NYC6 is offline   Reply With Quote
Old 03-25-2011, 05:09 AM   #6
Dean Prevolos
CF Member
Thanks for all the responses. I will take another look at them and take Gold 72 advise to buy one and take the educated guess when I change it out. Hopefully it is just one of them.
And to NYC6, I do not have an extended warranty. Thanks.
Old 03-25-2011, 06:38 AM   #7
Andy 53
CF Senior Member
Andy 53's Avatar
I would suggest buying two. If I recall correctly, they were not that expensive.
Considering it is a 2005 model, both are probably worn out. I had to replace both on my 2005 last year.
Andy
Reload this Page 05 Hood Struts won't stay open
Tags
2005, 2006, ahood, c5, c6, corvette, corvettes, hood, open, replace, stay, strut, struts, supports, wont
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
