Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-22-2011, 09:23 PM   #1
giarcmo
Junior Member
giarcmo's Avatar
Default Tire won't take air
Hi I have a problem with my front passenger tire , It won't take air. The pressure is down to about 23 lbs after sitting all winter , has anyone had this problem ? If so, is it as simple as a valve stem or with the tire pressure sensors is it more involved than that ? Also is it safe to drive with the pressure that low. Any help would be greatly appreciated .
giarcmo is offline   Reply With Quote
Old 03-22-2011, 10:47 PM   #2
BearZ06
CF Senior Member
St. Jude Donor '09-'10-'11-'12-'13-'14
BearZ06's Avatar
If your air chuck is good, the valve stem may need to be replaced. Will it work on the other tires? It shouldn't hurt to drive it slow, 30-40 mph.
BearZ06 is offline   Reply With Quote
Old 03-22-2011, 11:06 PM   #3
'VETTE PHASE
CF Senior Member
Cruise-In VIII Veteran
'VETTE PHASE's Avatar
Quote:
The valve stem is the pressure sensor.
You can drive it with 0 pressure safely, they're runflats.
'VETTE PHASE is offline   Reply With Quote
Old 03-23-2011, 07:55 AM   #4
mike72
CF Senior Member
check to make sure the small O ring from the cap has not come loose and gotten lodged in the stem. This has happened to others.
mike72 is offline   Reply With Quote
Old 03-23-2011, 08:11 AM   #5
giarcmo
Junior Member
giarcmo's Avatar
Is the stem different than your normal valve stem ? Thank You for your help !
Old 03-23-2011, 01:05 PM   #6
RicK T
CF Senior Member
RicK T's Avatar
Quote:
More often than you may think.
Yes it's different in that the stem is part of the wheel sensor.
Pic:
http://forums.corvetteforum.com/1561341919-post5.html
RicK T is offline   Reply With Quote
Old 03-23-2011, 02:49 PM   #7
giarcmo
Junior Member
giarcmo's Avatar
Checked for the o ring , valve stem looks clear thanks for all the advice I think I'll bring it to the dealer and have them take care of it
Old 03-23-2011, 03:23 PM   #8
Dave S
CF Senior Member
Support Corvetteforum!
Dave S's Avatar
The valve CORE may be defective....cheap & easy to replace yourself. All you need is a slotted valve cap or the little slotted tool that all auto parts stores sell. The cores themselves are very cheap....usually less than a buck each. Just unscrew the existing core....watch your face that it doesn't fly out from the tire air pressure. Screw in the new core & inflate the tire.....2 minute job. If that doesn't work, then something's wrong with the TPS & the tire will have to be dismounted.
Dave S is offline   Reply With Quote
Old 03-23-2011, 06:33 PM   #9
k24556
CF Senior Member
Default Valve stem
So if it does not take air, then the air hose chuck is not pressing the shrader valve in to open the valve. If you look into the valve stem, you will see what looks like the head of a pin. It should be flush with the end of the valve stem. If it is too far in, then the chuck won't press it. All you need is a valve stem tool to replace the little valve. When you take it out all the air will come out of the tire. put the new one in flush.
If you are using an air supply at a gas station, it may be worn or broken so it does not work the shrader properly. Try another one somewhere else.
Also, here in the South, we have insects that will nest in exposed little places and crud up things like valve stems. keep caps on everything.
k24556 is offline   Reply With Quote
Old 03-23-2011, 07:23 PM   #10
VET4LES
CF Senior Member
VET4LES's Avatar
Quote:
This would be my first thing to try.
VET4LES is offline   Reply With Quote
Old 03-23-2011, 09:14 PM   #11
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill Curlee's Avatar
This is a C5 Late model Tire pressure sensor. It looks very similar to the C6 sensor and yes,,, the STEM is part of the sensor:
Click the image to open in full size.
Theres a RUBBER gasket inside the tire stem cap. Sometimes the valve stem CUTS the gasket and the cut part enters the valve stem. When it does, it will NOT allow air to pass Just use a pick and dig it out. Try pressing the small valve inside the stem and See if air will come out.
BC
Bill Curlee is offline   Reply With Quote
Old 03-23-2011, 09:16 PM   #12
johnodrake
Moderator
johnodrake's Avatar
Johnodrake @CdrDrake johnodrake
johnodrake is offline   Reply With Quote
Old 03-24-2011, 04:27 PM   #13
giarcmo
Junior Member
giarcmo's Avatar
Well after looking closer (with my glasses on this time) turns out all it was was the rubber gasket from the cap. Thanks for everyone's help. You gotta love when its a simple fix !!!
Old 03-24-2011, 04:31 PM   #14
RicK T
CF Senior Member
RicK T's Avatar
Told you.
Old 03-24-2011, 10:01 PM   #15
C6topless
CF Senior Member
C6topless's Avatar
Default TPS in the C6
Had a tire pressure sensor give out and stop functioning. After it was swapped and I reprogramed it, I spoke to my tire man about the cause of this failure.
According to him, these sensors have internal batteries that have a life span of about 8-10 years. He further went onto state, they are not rebuildable as they are factory sealed.
It is his opinon that there will be a lot of TPS sensors going out in the near future. He also warned me about the dangers of liquids being intoduced into the tire as it can cause TPS sensors to fail ( i.e. Fix-a-flat compound... personally I have never it but those using tires that are non-runflats may be temped ). Thought I would pass this along...
C6topless is offline   Reply With Quote
Old 03-24-2011, 11:40 PM   #16
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres a fix for that. They sell generac aftermarket C5 sensors now that beat GM prices easily. Theres also a battery change fix thats easy enough to accomplish,, and its very inexpensive.
-Check out the links
- Tire pressure sensor rebuild - http://forums.corvetteforum.com/c5-t...post1570376652 http://forums.corvetteforum.com/c5-t...-tutorial.html http://forums.corvetteforum.com/c5-t...post1575112894
Old 03-26-2011, 02:02 AM   #17
C6topless
CF Senior Member
C6topless's Avatar
the C5 sensor is different from the C6 in design based on my visual inspection of the two and this design change may prevent the fix like that done in the C5 TPS. However with that said, you are absolutely correct that the C5 can be refitted with a new battery. But it is my understanding, the new C6 sensor cannot at this time ( it is the solid grey TPS -- which also needs a reprogramer rather than a magnet to set ) ... Also to the best of my knowledge ( I am sure if I am wrong someone will tell me ) the C5 TPS will not function in a newer C6 that came with the grey TPS.
Perhaps I will collect up some dead C6 sensors and in my spare time work on correcting this problem
Old 03-26-2011, 09:23 AM   #18
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres a link with pictures of a C6 sensor. Your are CORRECT. The C5 Sensor will NOT retrofit into a C6.
http://forums.corvetteforum.com/c6-t...05-wheels.html
Reload this Page Tire won't take air
Tags
1997, accept, air, car, corvette, inflate, sensor, spare, stem, stuck, tire, tires, valve, valvle, wont
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
