05 window indexing problem
Old 12-19-2012, 10:42 PM
MaggieH
8th Gear
MaggieH's Avatar
Fixed
Old 12-19-2012, 11:19 PM
loudvolvo
loudvolvo's Avatar
if it were me id unhook the battery for awhile then reset the windows. may not work but its worth a shot.
Old 12-19-2012, 11:42 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Have you tried resetting the window indexing?
With the engine running and the window down, close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window. (This is in the owner's manual.)
You'll need to do this every time the car battery is disconnected, then reconnected.
Old 12-20-2012, 11:51 AM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ALSO,,, if you have a WEAK battery, it will crank and start the engine but,, it can also allow the battery OUTPUT voltage to drop low enough cause all the factory settings and the INDEX to reset. (Ask me how I know this??)
Recharge your battery and take it to AUTOZONE or ADVANCE and have it fully tested for CCA and reserve capacity.
What is the procedure that you are using to reindex your windows???
Bill
To 05 window indexing problem
Quick Reply: 05 window indexing problem
