Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- How to Replace Window Regulator
Step by step instructions for do-it-yourselfers.
Window Regulator Replacement Help
2005 Z51 Corvette
Bought a used drivers side window regulator off of ebay (also a forum member and thanks by the way). My mechanic was recently let go and now I have to undertake the install.
Any links to replacement instructions would be helpful.
Thanks in advance.
Thanks in advance.
Search is your friend:
http://forums.corvetteforum.com/c5-t...wr-window.html
Make sure you clean the contacts and that are all aligned properly before installing. Make sure they install tight. Giood Luck
