lowering corvette c6
Old 02-04-2011, 09:09 AM
miche25
miche25's Avatar
Default lowering corvette c6
Hello,
Can I use the rear lower bolt stock to lower a "3/4 inch.
If so, owe I turn in the meaning of the hand of the watch (left-right) or the opposite.
Michel
Old 02-04-2011, 10:59 PM
corvette dave
corvette dave's Avatar
Each car is different in how much they lower. 3/4" is more than I have ever seen. Turn the bolt counterclockwise (left) to lower.
Old 02-05-2011, 11:34 AM
taken19
Track Junky
taken19's Avatar
I got about 5/8' out of my stock fronts but only 1/4' our of the rears. Had to take everything apart and trim the pad a bit to get 3/4 total travel.
Do a search and you'll find plenty of info. This website gives you an idea of what you would be up against if you trim the rears. I added a small dab of grease to prevent squeaking when I re-installed.
http://www.vetteweb.com/tech/vemp_07.../photo_01.html
Old 02-05-2011, 09:50 PM
jpgolf14
jpgolf14's Avatar
i had about the same amount of lowering by turning the front and back bolts. i ended up cutting one rib off the back bolt to get it the drop i was looking for.
To lowering corvette c6
Quick Reply: lowering corvette c6
