Scorpion Race Series Roller Rocker Arms [GM LS1, LS6, LS2, L92, LS3 & LS9]
Old 01-26-2011, 01:29 PM
COSPEED
COSPEED's Avatar
St. Jude Donor '10
Default Scorpion Race Series Roller Rocker Arms [GM LS1, LS6, LS2, L92, LS3 & LS9]
All Scorpion Rockers Feature:
Needle Bearing Fulcrum and Roller Tip, Centerless Ground Trunnion, Centerless Ground Pin & Roller, Burr-Free Thru Hole in Trunnion, Large Machined Seat, Thick Walled Adjusting Nut, Pedestals Machined from Solid Steel, Black Oxide Coated Steel Parts, & 100% CNC Machined. Other benefits include:
• Available in all ratios
• Lightweight for maximum performance
• Easily handle .950” lift and 950 lbs of open spring pressure
• Clear 1.625” valve springs
• Micropolished surfaces finish for maximum durability
• Anodized for additional protection and aesthetics
• Exclusive LIFETIME WARRANTY - all series
• Available ratios 1.7-1.8 Chevy LS engines
• The only ‘No Machining Required’ kit in production
• No changing pushrods, guide plates, rocker studs
• No need for valve cover spacers
Scorpion Race Series Roller Rocker Arms, 1.7:1 (GM L92, LS3 & LS9) [SCP1062] - $551.50 SHIPPED
Chevy V-8 L92-LS9-LS3 - Non-adjustable. No machining required.
Scorpion Race Series Roller Rocker Arms, 1.7:1 (GM LS1, LS6, LS2 & LQ9) [SCP1098] - $372.26 SHIPPED
Chevy V-8 LS1-LS2-LS6-LS364/400-LQ9 - Non-adjustable. No machining required.
PLEASE EMAIL US FOR PAYMENT INFO. THANKS.
CURRENT DISCOUNT COUPON CODES
If you have any questions, please e-mail us as we do not frequent CORVETTE FORUM and may not answer any posts in a timely manner. Thank you.
Old 03-03-2011, 04:51 PM
Sparo2
Sparo2's Avatar
What's the reason why the these lifters can't work with LS3 motors. I have a LS2 motor with a LS3 topend.
Old 03-29-2011, 02:17 PM
08VRZ06
08VRZ06's Avatar
Cruise-In X Veteran
What about the LS7? Are any made for it???
Mark
Old 04-08-2011, 12:07 AM
Redrocket1045
Redrocket1045's Avatar
I have a couple of questions concerning these rockers. Is the rocker arm body a CNC aluminum piece? And question #2 - I have Billet Custom Products valve covers - and just for peace of mind before I place an order - will these rockers fit without any fitment problems? TIA
Old 04-12-2011, 10:00 PM
Redrocket1045
Originally Posted by BYUN SPEED
"Needle Bearing Fulcrum and Roller Tip, Centerless Ground Trunnion, Centerless Ground Pin & Roller, Burr-Free Thru Hole in Trunnion, Large Machined Seat, Thick Walled Adjusting Nut, Pedestals Machined from Solid Steel, Black Oxide Coated Steel Parts, & 100% CNC Machined. Other benefits include:"
If the spacing is the same then yes.
Ordered my set today.
Old 05-16-2011, 02:51 PM
BDub874
Navigator
BDub874's Avatar
Are the needle bearings on the rocker arrms caged, or cageless like the oem?
Old 07-23-2011, 07:00 PM
FloydSummerOf68
FloydSummerOf68's Avatar
All things equal, in a cammed car, will the Scorpion 1.7s make more power? Or is it just a better than stock replacement piece for valvetrain insurance?
Old 09-17-2011, 05:02 AM
wiggins82abn
wiggins82abn's Avatar
Default Order Placed
I just placed my order for the Scorpion LS2 Rockers and Patriot LS Gold Springs.
Old 10-10-2011, 09:52 PM
383's Avatar
Would be good to know.
Old 11-23-2011, 12:32 AM
jon6.0
jon6.0's Avatar
How much for 1.8 ratio for LS3? What is the open and seat pressure on the Lunati springs?
And just to be clear, I don't need a new pushrod length with the rockers?
Old 05-05-2012, 06:48 PM
thetitan
thetitan's Avatar
Will these rockers in 1.8 ratio clear the valve covers on a stock 98 ls1 with the perimeter bolt valve cover and stock cam?
Thanks, Titan
Old 07-16-2012, 01:11 PM
5 Liter Eater
5 Liter Eater's Avatar
St. Jude Donor '11
My stockers have a good amount of play in them so I need to do something. I'm torn between getting these and doing the trunion upgrade in mine. The benefit of these is that if I change to an aftermarket casting head, roller tips are required due to the bronze valve guides so I'd already have them.
Old 02-10-2013, 06:26 PM
jon6.0
jon6.0's Avatar
An answer would be nice.
Old 10-11-2014, 04:43 PM
COSPEED
COSPEED's Avatar
St. Jude Donor '10
Old 12-11-2014, 02:37 PM
Mr.Nubain
Mr.Nubain's Avatar
Location: If you wanna live life on your own terms, you gotta be willing to crash and burn Florida
Would 1.7 increase power in a LS2 or would it do nothing. I'm not planning on putting in a cam either. I see the question was asked, but never answered. I was searching on roller rocker stuff and didn't see much. Without modding the valve covers either.
To Scorpion Race Series Roller Rocker Arms [GM LS1, LS6, LS2, L92, LS3 & LS9]
Quick Reply: Scorpion Race Series Roller Rocker Arms [GM LS1, LS6, LS2, L92, LS3 & LS9]
