*** The C6 Ultimate DIY Thread****UPDATED***
Old 12-21-2010, 09:21 AM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default *** The C6 Ultimate DIY Thread****UPDATED***
The purpose of this thread is to try and consolidate all of the DIY and How To's posted here in the tech section. I know alot of forum members have posted threads on how to do alot of stuff from swapping out lights to fluid changes and painting calipers. Alot of these threads have some great information and some very helpful pics and tips so in an effort to get everything in one place and save some time searching I encourage you to let me know about a good DIY thread so I can include it here. I am not saying don't post it in the section but let me know and I will add it here so it will be easier to find in the future.
I will start a table of contents in this post and try and update it as things are added...please PM me if you post an article in here so I can update the TOC.
Table of Contents:
Post #2 David Farmers Torque Specs and Trouble Codes
Post #3 Links to the Old Tech Tips etc
Post #5 How to replace a fuel pump
Post #broken link
Post #10 Intake removal and FAST 102 install LS2
Post #12 Full LS2 exhaust install, headers back.
Post # 13 C6 Partition for less than $20
Post # 14 HID Foglight install with instructions and pics
Post # 15 L92 Monster H/C package dyno numbers and cam specs
Post # 16 Traction Monster..part of the solution
Post #17 FLYCUT Monster, making big cams fit with optimum compression
Post #18 Twin turbo Monster, I take a crack at bringing the pricing down to earth
Post #19 Methheadmonster Using Meth-injection-for-non-boost-applications
Post #20 C6 Z06 Front Brake Duct Install w/pics
Post #21 e85 Monster Conversion for e85
Post #22 Big 3 Install on C6 w/pics
Post #27 Convertible speaker upgrade
Post #28 How to remove the center console/radio bezel in the C6
Post # 29 DIY Sub Box Dimensions
Post #30 BCM Plug Pinouts from 2007 service manual
Post # 31 C6 Radio Schematics and Plug Pinouts
Post # 32 2012 Seat Conversion
Post #33 Zr1 front end conversion
Post #34 2005 LS2 to LS3 dry sump DIY
Post #35 [Beware: LS3 timing chain tensioner] aka: DIY Oil Pan removal guide
Post #38 Resetting TPMS using different handheld tools
Post #44 tr6060 manual transmission teardown-and-rebuild
Powelltc1 (11-01-2018)
pewter99
pewter99's Avatar
Default David Farmers Torque Specs and Trouble Codes
http://forums.corvetteforum.com/c6-t...info-here.html
Old 12-21-2010, 09:22 AM
pewter99
pewter99's Avatar
Default Links to the Old Tech Tips etc
http://forums.corvetteforum.com/c6-t...tions-too.html
Old 12-22-2010, 08:24 PM
pawpaw4
pawpaw4's Avatar
Old 01-09-2011, 08:13 AM
pewter99
pewter99's Avatar
Default How to Replace a Fuel Pump
http://forums.corvetteforum.com/c6-t...fuel-pump.html
Vegeta9716 (03-15-2023)
Old 02-19-2011, 07:56 PM
BigDs_C6
BigDs_C6's Avatar
Here's a link for a good DIY cam install PDF...
*********broken link removed
Old 02-28-2011, 10:32 PM
jwoodroof
Cruising
jwoodroof's Avatar
Default 9 volt temp power for presets
I would like to know if a plug with a 9 volt batt. in cig. lighter can be used on a C6 to power presets while the car battery is disconected ?
Old 04-17-2011, 11:55 AM
debo
debo's Avatar
888888888888888888
D
That's a great write up, but definitely need more pictures explaining each step.
Old 04-27-2011, 12:52 AM
hep100
hep100's Avatar
[QUOTE=BigDs_C6;1576839598]Here's a link for a good DIY cam install PDF...
I'm sure some folks on here could add some other pointers to make it the "ultimate" cam install DIY.
Great write up, note if you have a Z51 there are a few more steps and you will have to discharge your ac and pull the condenser to get the rad out.
Old 05-03-2011, 09:35 AM
TNTC4VETTE
Will work for HPDE time.
TNTC4VETTE's Avatar
Default Intake removal and FAST 102 install LS2
FAST 102 install:
http://forums.corvetteforum.com/c6-t...with-pics.html
Factory LS2 intake removal:
http://forums.corvetteforum.com/c6-t...val-steps.html
Old 05-03-2011, 11:47 AM
taken19
Track Junky
taken19's Avatar
A few more steps indeed, but it can be done without discharging the AC. It's a tighs squeeze, but you can leave the A/C condenser in the engine bay.
Old 05-03-2011, 02:22 PM
TNTC4VETTE
TNTC4VETTE's Avatar
Default Full LS2 exhaust install, headers back.
http://forums.corvetteforum.com/c6-t...ll-thread.html
Old 08-20-2011, 11:07 AM
bdanyluk
bdanyluk's Avatar
Default C6 Partition for less than $20
Go to the hardware store and get a 12" x 72" x 3/4" piece of pine for less than $15.
Can of black spray paint for $3.
Cut to dimensions/pictures below.
Paint.
Enjoy! ( yes that is a spare tire hard-mounted to my trunk floor )
06Rawpower (06-19-2019)
Old 12-10-2011, 09:10 AM
pewter99
pewter99's Avatar
Default HID Foglight Install with pics
Old 12-10-2011, 09:12 AM
pewter99
pewter99's Avatar
Default L92 Monster H/C package dyno numbers and cam specs
http://forums.corvetteforum.com/c6-t...cam-specs.html
Old 12-10-2011, 09:13 AM
pewter99
pewter99's Avatar
Default Traction Monster..part of the solution
http://forums.corvetteforum.com/c6-t...-solution.html
Old 12-10-2011, 09:15 AM
pewter99
pewter99's Avatar
Default FLYCUT Monster, making big cams fit with optimum compression
http://forums.corvetteforum.com/c6-t...mpression.html
To *** The C6 Ultimate DIY Thread****UPDATED***
Old 12-10-2011, 09:16 AM
pewter99
pewter99's Avatar
Default Twin turbo Monster, I take a crack at bringing the pricing down to earth
http://forums.corvetteforum.com/c6-t...-to-earth.html
Old 12-10-2011, 09:18 AM
pewter99
pewter99's Avatar
Default Methheadmonster Using Meth-injection-for-non-boost-applications
http://forums.corvetteforum.com/c6-t...lications.html
Old 12-10-2011, 09:20 AM
pewter99
pewter99's Avatar
Default C6 Z06 Front Brake Duct Install w/pics
SERENITY_NOW (09-01-2016)
Quick Reply: *** The C6 Ultimate DIY Thread****UPDATED***
