Hard Shifting on my C6
Old 12-09-2010, 10:40 PM
4howard
4howard's Avatar
Default Hard Shifting on my C6
I just bought a beautiful 09 AO MN6 Z51 Coupe with 2100 miles this Sunday and it is awesome. The power and the ride quality appear to be light years ahead of my 04 Vert, which is a great car in its own right. My question is the shifter in the C6 seems a lot harder to change gears, especially when cold. What is more puzzling is sometimes when going from first to second or second to third it does not shift smoothly at all, it sort of feels like the clutch is not fully depressed, like the gears would be bumping and not meshing. Is this normal for the C6?
Old 12-09-2010, 11:26 PM
doveboat
doveboat's Avatar
That sounds normal based on my 08 MN6, will be notchy on the 1st to 2nd shift till warmed up. I have 36k and still have the same cold shifting.
Once warmed up all is fine, just a characteristic of the car.
Ed
Old 12-10-2010, 12:04 AM
Rebel 1
Rebel 1's Avatar
My '09 M6 had the exact same issue as yours. I don't know why but when the car hit about 4,500 miles, no more notchy shifts. It was a little aggravating when cold.
Bob
Old 12-10-2010, 10:11 AM
SG4206
SG4206's Avatar
My '10 GS does the same ; however ,the skip shift fuse helps the problem a little.
Old 12-10-2010, 11:51 AM
Ragtop 99
Ragtop 99's Avatar
Received 1,181 Likes on 681 Posts
On 30* mornings I double clutch the 1-2 and 2-3 for the first few miles. The shifter loosens up and the grinding doesn't occur. After about 5 miles the shifts are like a normal summer day, buttery smooth.
Old 12-10-2010, 04:18 PM
4howard
4howard's Avatar
Do you mean to say if I install the CAGS bypass gizmo the problem will be less?
Old 12-10-2010, 04:36 PM
Ragtop 99
Ragtop 99's Avatar
no. He's saying it might force you from 1st to 4th at light throttle and by pass 2nd gear. Skip shift is programmed to work after the car warms up a bit, so I don't see this helping.
As much as it sucks, the TR6060 tranny does not like the cold. Some have tried using other brands of tranny fluid in hopes of finding one that is more cold weather friendly.
http://forums.corvetteforum.com/c6-c...-grinding.html
Old 12-10-2010, 04:50 PM
CO Lightfoot
CO Lightfoot's Avatar
Congrats on your new C6!
Cold-shifting issues are not unique to the C6. I've read about similar problems with Porshes, Vipers and other big-hp cars. Definitely on an 03 Mach1 I used to own.
With only 2100 miles, it should get better with more miles. Might want to get the dealer involved now, just to document it in case it gets worse later.
BTW, the Z51 OEM supercar tires also hate the cold. Be careful.
Of course, be sure to check your clutch fluid and keep it clean:
Old 12-11-2010, 06:01 PM
4howard
4howard's Avatar
Thanks!
Old 03-31-2012, 09:19 PM
Nik_Bad
Nik_Bad's Avatar
My 08 C6 had the same issue in the cold. The other evening, however, it was a warm night (73°F) and I was having issues with rough shifts. They felt different than the cold ones. Any clue what might be going on? My car has 21k.
Old 03-31-2012, 09:33 PM
Boomer111
Boomer111's Avatar
Is your clutch/brake fluid clean?
I know dirty fluid can cause clutch problems.
Old 04-01-2012, 12:17 AM
k wright
k wright's Avatar
Search for the Anti-venom mod and then do it.
My guess is that you are accoustomed to imports and the effort required to shift them.
The effort required to shift the Corvette is due mostly to the centering spring which in my hands is way to stiff.
A tiny change in your car will make your shifting far more precise.
ken
To Hard Shifting on my C6
Quick Reply: Hard Shifting on my C6
