LS3 - Vararm Pre-Cut Shroud
Few Questions:
A. Does anyone know where you can purcahse one?
B. If you can't purchase one, will the LS2 Shroud fit?
C. If the LS2 Shroud won't fit, where can I get the template to cut the factory shroud?
Thanks!!!
-Narsh
Thanks!!!
-Narsh
You should contact Vararam. I think they sell precut shrouds, I'm not sure of that but it would be worth the call. They will send you a template if nothing else. It's easier to cut your shroud than pulling it out and replacing it.
removing your old shroud
I installed the VaraRam and love it but was not loving it when I was installing it. The problem is the instructions need to be changed if you are trying to remove the original shroud without cutting it. Good luck and be prepared to tug more then gently like there directions say.
Almost through it all in the box and sent it back but glad I did not..
Good luck and hopefully they will change the instructions soon.
