Brakes worn, replace with stock or upgrade?
I have a 2009 base Corvette (non-Z51) with 39k miles on it. Just replaced my rear tires yesterday and apparently my brakes are worn. Interestingly enough the rear pads are worn down more than the fronts. Anyway, apparently rotors are thin on these cars and I hear most people just replace them instead of resurfacing them? I was wondering if I should just stick with stock pads and rotors or if there's a suitable upgrade in the aftermarket that wouldn't cost much more?
This is a daily driver so I don't want to replace it with something that will wear any quicker or cost considerably more. I know that sometimes OEM is more expensive than aftermarket for less performance so if someone can recommend pads and/or rotors that will give me better stopping power or better wear for around the same price I'd love to hear it!
St. Jude Donor '09
Unless you're tracking the car you are probably fine with replacement rotors. If you want better performance and truly directional rotors, I'd look at DBA rotors. There's a forum vendor here who can hook you up.
For pad options you need to ask yourself if you're willing to put up with more brake dust. If you're pads aren't dusting, they're not working very hard. If you're truly after performance, you have to put up with the extra dust.
San
oldmansan, OK, I'll probably stick with the stock rotors. Any recommendations where I should buy them for the best price?
I'm willing to put up with more brake dust for better performance since I wash the car every single week. But will I get reduced pad life out of better performing pads always?
St. Jude Donor '09
You will usually sacrifice some durability for better performance. For street use you may just want to go with a moderately aggressive pad to give you more performance with decent durability.
I run Carbotech Bobcat pads on my WRX and Axxis pads on my C6 (came with my Stoptech kit).
San
St. Jude Donor '09
Sir, I have these on my 07 Z51 and like them a lot.
http://shop.performanceafx.com/C6-Z51-Corvette_c15.htm
San
Tolero Apto Victum
Supporting Vendor
St. Jude Donor '11,'13
Retail price.
F $144 R $124
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
