Which AC Delco Oil Filter?
Old 10-19-2010, 03:23 PM
BevoZ06
BevoZ06's Avatar
St. Jude Donor '11-'12
Default Which AC Delco Oil Filter?
Which AC Delco oil filter should I use on my 2006 LS2 6liter engine? I have seen conflicting recommendations between PF44 and PF48. I don't have the car and manual with me, but I want to pick up the oil and filter on the way home.
Thanks.
Colin
Old 10-19-2010, 03:35 PM
///DarkSide\\\
///DarkSide\\\'s Avatar
St. Jude Donor '12-'13-'14-'16-'17-'18-'19-'20-'21-'22-'23-'24
Purolator PureOne = 99.9% one pass efficiency
Old 10-19-2010, 03:37 PM
BevoZ06
BevoZ06's Avatar
Default AC Delco
Originally Posted by ///DarkSide\\\
Purolator PureOne = 99% one pass efficiency
Thanks, but I am inquiring specifically about the AC Delco brand.
Old 10-19-2010, 03:55 PM
sevinn
Support Corvetteforum!
sevinn's Avatar
St. Jude Donor '14, '16
pf46, or pf46e (chances are you will only find the latter)
same as my 05, but I checked just to be sure on the Delco site
Old 10-19-2010, 04:06 PM
BevoZ06
BevoZ06's Avatar
That's what I thought, and that's what I use on my two C5s. Gene Culley's GM Parts House Web site says PF44 for the 2006 LS2. That's part of my confusion.
Thanks for the reply.
Old 10-19-2010, 05:44 PM
NYC6
NYC6's Avatar
Just to verify, PF46 been used in my 06 since I bought it new.
Old 10-19-2010, 06:00 PM
Zip Corvettes
Platinum Supporting Vendor
Zip Corvettes's Avatar
A 2006 LS2 uses a PF-46E or PF-46
Old 10-19-2010, 07:27 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
PF46 superseded the PF44. Either one will work. Or you can use the UPF44 premium filter
Old 10-19-2010, 09:02 PM
BevoZ06
BevoZ06's Avatar
Thanks for the replies. I picked up three PF46E filters.
Colin
Old 10-20-2010, 07:38 AM
GOLD72
GOLD72's Avatar
Received 1,103 Likes on 717 Posts
The 2006 LS2 was the last year that used the 44/46 series filters. The 2007 LS2 and 2008 LS3 uses the 48 series. The 48 series uses a different mounting thread pitch so don't even try to use a 48 series on a 2005/2006 LS2!!!!!!
Old 10-20-2010, 02:32 PM
BevoZ06
BevoZ06's Avatar
Thank you, Gold72. I got the oil and filters changed this morning on two of my Vettes. The third one is not quite due, so I will hold on to the other PF46E. Thanks especially for the warning on the different thread pitch.
Colin
Old 10-20-2010, 04:29 PM
Bandit1
Bandit1's Avatar
I use the UPF44 on my 06 and get them from Gene at GMPartsHouse,
Old 10-20-2010, 10:15 PM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Actually, I list the UPF44, which is the UltraGuard filter that filters further down in microns, etc. There is no UP (UltraGuard) version of the PF46, which is why I recommend the UPF44.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Gene Culley
Thank you for your support!
Old 10-21-2010, 08:07 AM
GOLD72
GOLD72's Avatar
Colin
You are welcome! It can be very confusing for those that didn't have LS series engines during that transition period and do now. The PF48 was introduced first for the 2006 Z06-LS7 engine because GM moved the pressure relief device from the block to the filter. The mounting thread pitch was changed to prevent interchangeability with the older 44/46 series filters. Only in MY2007 did GM standardize on the 48 series filter for the LS2. If you own an LS2, it is essential to know the model year and the correct filter series for that year!!
Some more background info: The PF44 was replaced by the PF46 six or seven years ago (with the exception of the premium UPF44). The only difference is that the PF46 got improved internal media. I have no idea why GM/AC Delco decided to change the model designation to PF46. Why not keep it as PF44? The 44 and 46 series are dimensionally interchangeable.
Old 10-21-2010, 12:29 PM
BevoZ06
BevoZ06's Avatar
Thank you, Gene, for this clarification and for your support of the forum and its members.
Colin
Old 10-21-2010, 02:18 PM
3 Z06ZR1
3 Z06ZR1's Avatar
I'd use a Wix! Ever since I found a A/C Delco filter that was made by Super tech. Or the same company as this A/C was the exact same internally as the Walmart Super tech. I'll use a Wix!
To Which AC Delco Oil Filter?
Old 10-21-2010, 07:43 PM
rmp
rmp's Avatar
That's what I've been using on my 2006 since I bouught the car.
Old 10-21-2010, 09:16 PM
danl72
danl72's Avatar
Thanks.
Colin
PF48 is for the LS3.
Old 10-21-2010, 09:24 PM
GOLD72
GOLD72's Avatar
PF48 is also for the 2007 LS2.
Quick Reply: Which AC Delco Oil Filter?
