Do you think I have an aftermarket cam? Looking to add more power.
Old 08-17-2022, 08:34 PM
jimih941
jimih941's Avatar
Default Do you think I have an aftermarket cam? Looking to add more power.
M6 ls2 with a 91 tune made 392hp and 430 tq. Full bolt on. Dyno done on a chassis dyno. The guy I bought it from said it had a small cam, although I do not hear much chop to the exhaust. Based on the much higher torque, I’m thinking there may be a cam and the heads are limiting the hp. I’m thinking of adding heads only if it has a cam or both heads and cam if not. My goal is to make around 430rwhp. Im not sure how to check if there’s a cam but would prefer not to put another cam in if there’s already an aftermarket cam.
thoughts?
Old 08-17-2022, 08:39 PM
jimih941
jimih941's Avatar
And the follow up… if I add just heads, what size springs would be safe to go with? 660?
Old 08-17-2022, 10:01 PM
bwill03z
bwill03z's Avatar
Did the person you bought it from put the cam in it? If so he should have given you the info on it. Maybe a tuner can chime in and give you an answer based on the dyno numbers but can you post an idle video so we can hear?
Old 08-17-2022, 10:10 PM
jimih941
jimih941's Avatar
I’ll definitely get a video.
unfortunately I bought it from a dealership and they told me the guy that traded it in said it had a cam.
Old 08-17-2022, 10:14 PM
bwill03z
bwill03z's Avatar
Yeah it has a cam, the stock cam lol. Jk yeah post a video I’m sure someone will be able to tell.
Old 08-18-2022, 06:35 AM
Spaceme1117
Spaceme1117's Avatar
Received 1,313 Likes on 885 Posts
Very likely it has a small cam. My 2006 GTO with the LS2 dyno'd right at 400 wheel hp and tq with a very mild cam. Stock wheel hp and tq should be closer to 350.
Old 08-18-2022, 08:18 AM
jimih941
jimih941's Avatar
Here’s the video
YouTube start and idle
https://youtu.be/ddra3v9u-V0
Old 08-18-2022, 05:01 PM
ptroxx
ptroxx's Avatar
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
id say a hard no on the cam.
here’s a cold start of mine with a tiny CA cam I had
jimih941 (08-18-2022)
Old 08-18-2022, 05:11 PM
bwill03z
bwill03z's Avatar
I mean it could have a baby cam in it but it def sounds stock.
To Do you think I have an aftermarket cam? Looking to add more power.
Quick Reply: Do you think I have an aftermarket cam? Looking to add more power.
