Cast to Forged
Cast to Forged
Have a 08 with a set of aftermarket cast wheels. 30 series on frt, 25 series in bk. Have to add air everyother day, tire shop said they are flaking & have corrosion. Looking at a set of COR forged wheels. They are 20's with 25 series tires, hoping to solve my problem. Any input would be appreciated.
You may run into problems with the Active Handling. If you don't maintain the correct % difference of front wheel rotation to rear wheel rotation the computer will get confused and think the tires are spinning and activate the system. I'm definitely no expert on this so I'll just refer you to this current thread. You can contact the members in there who know this stuff. Good luck.
http://forums.corvetteforum.com/c6-t...active-on.html
