Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-23-2010, 07:12 PM   #1
michc63563
Junior Member
Default F85 Shock / elctronic suspension elimination
Looking for some advice on improving my C6 suspension. An having a and e-force super charger installed and wanted to improve the suspension at the same time. It's a stock c6 and I had z51 sway bars installed and am trying to install Bilstein shocks. Problem is I have electronic suspension and F85 shocks that are electronically contolled. If they're unplugged a mil light (check light) goes on and the cars speed is limited to 80mph (who wants that!). I bought a plug in kit from CorvetteGarage who got it from Casperselctronics that is supposed to plug right in and eliminate the issue. Problem is the part we received is close but the locking tab is wrong and it won't plug in. Box says it's for 2005+ and mine is 2007 so that's correct. Part num we have is 109096. My garage guys say they spoke to Casper and described the issue and were told we need part# 109066 but that one is for C4/5. What's up? Is it possible that GM used F85s on my car that were from C4/5 era? CorvertteGarage does not seem to know what's wrong.
michc63563 is offline   Reply With Quote
Old 09-23-2010, 07:35 PM   #2
michc63563
Junior Member
One more thing. I guess I interested in whether this make sense to do or whether I should send the Bilsteins back and stick with the electronic adjustable suspension I have??
Old 09-23-2010, 07:53 PM   #3
RicK T
CF Senior Member
RicK T's Avatar
Quote:
I wasn't going to post in this thread 'cause I don't have the knowledge you're looking for. But, as to this question........I don't recall anyone going to the trouble to switch out the F55's for a standard shock, Bilstein or anything else. There probably are some who have but I don't know of any. Those who remove the F55's "usually" do it to go to coil overs. A better track set up and pretty nice on the street too.....but spendy.
Here's just a little info, you may want to contact these folks:
http://forums.corvetteforum.com/1572360729-post10.html
http://forums.corvetteforum.com/1574586205-post15.html
RicK T is offline   Reply With Quote
Old 09-23-2010, 09:21 PM   #4
Zoxxo
CF Senior Member
Zoxxo's Avatar
Quote:
My wife and I did it on her C6. Removed her 2007 F55 system for QA1 shocks.
The shock simulators won't work. The C6 F55 system does a self test every so often and it expects to see variable results. The shock sims are resistors that return a fixed result which the system sees as wrong. This is all in the service manual if you read up on the F55 system.
It can be done. You will need a Tech2 unit as part of the solution. Some folks seem to be able to make it go away with just the Tech2 software routine. Others not so much.
Z//
Zoxxo is offline   Reply With Quote
Old 09-23-2010, 09:25 PM   #5
RicK T
CF Senior Member
RicK T's Avatar
Z//
One of your posts is the first one I linked above. I wasn't sure what you had switched to but your experience might help the OP.
Old 09-24-2010, 12:49 AM   #6
Zoxxo
CF Senior Member
Zoxxo's Avatar
Ahh. Ok. I didn't look at the links 'cause I'm thinkin' "who's gonna tell me more about this?"
Z//
Old 10-25-2010, 12:29 PM   #7
michc63563
Junior Member
I ended up using the shock simulators from Kasper Selectronics. Had to change out the connector. They said they only see the ones installed on my 2007 in one of 20 vehicles. No big deal though. The Bilstein shocks have been on for over a month now and no check engine light. Everything works great and the car handles a lot better.
Reload this Page F85 Shock / elctronic suspension elimination
Tags
2005, adjustable, caspers, corvette, electronic, eliminate, f55, shock, shocks, simulators, suspension
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
