Pictures of inside NPP muffler
The reason I ask is because I purchased a pair of NPP mufflers from a salvage yard on Ebay that was taken off a 2009 vette that had been in a roll over accedent. They have some dents but otherwise look fine. The probelm is one of the mufflers has some gravel in it and I want to get it out so my car doesn't rattle, it would be easier if I new how the muffler was contructed internally.
I have gotten some out by holding up and shaking but I am not Schwartenagger so any help would be appreciated.
And yes it was worth while to do it :-)
Stosh
Stosh
St. Jude Donor '09
Stosh
Stosh
San
You would think that the gravel would come out the same way it got in, through the exhaust tips. It is going to take some gyrations and lots of patience. You may look like Arnold before you are done.
Received 2,060 Likes
Here's a pic of a base muffler. Inlet on the left and exit on right.
The bi-mode (Z06/NPP) muffler quiet side (non-valved) exit is in the same location. The center compartment is filled with the fiberglass that is initially in a bag, but apparently the bag disintegrates over time, as only pieces were left in this muffler.
I suspect the gravel got in through the quiet side, which is always open. Follow that tube from the right to the U-bend on the left and then back to where it opens into the right compartment. That's where the gravel is now.
If you really want the gravel out, I'd suggest drilling a hole in the upper end panel, then shaking it out and welding the hole shut.
All, thanks!!
Yea, I have tried holding the things up and shaking them and got quite a bit out but not all. Very dissapointed in the Ahole who lied to me and told me there were no rattles !! I will see if I can get my money back thru Pay Pal or Ebay but if worst case I may try to drill 1/2 " holes to get the gravel out then weld them up.
All, thanks!!
jerry
Have the ufflers in a local garage who is attempting to cut open the mfflers to remove what I believe to be part of the catalytic converter that broke loose and was traped in the muffler. I also want to say the gentelman I bought the mufflers from appologized and offered my money back or will pay to have the repairs done. That is very refreshing to find an honest man!! Will let you know how it turns out. Thanks for everyones input!
Stosh
Stosh
They wouldn't work on them due to fiberglass??? What did they think was in there? It's not like it's asbestos or something bad. I mentioned fiberglass in post #7 and now it's a problem??
The following 2 users liked this post by MarkRx:
Justbs549 (04-30-2023),
OctagonMan (03-20-2019)
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Excellent picture!!
Keep on shaking!!!
Keep on shaking!!!
