Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-17-2010, 08:26 PM   #1
llllorac
CF Member
Default 2010 GS LS3 oil drain plug torque spec?
Anyone know the recommended torque specifaction for the 15mm oil drain plug?
llllorac is offline   Reply With Quote
Old 08-17-2010, 08:35 PM   #2
BEZ06
Formerly beezeye
Support Corvetteforum!
BEZ06's Avatar
Take a look at forum member David Farmer's great website for a link to documents with all the torque specs:
http://davidfarmerstuff.com
Bob
__________________
BEZ06 is offline   Reply With Quote
Old 08-17-2010, 09:35 PM   #3
Robls6
CF Senior Member
Robls6's Avatar
I tighten to three "Eeeeeeeh's"
Robls6 is offline   Reply With Quote
Old 08-17-2010, 09:36 PM   #4
jpee
CF Senior Member
jpee's Avatar
Bob
I'm sure you are correct by telling him to check the "Book" for the correct torque specs.. I think there is a torque spec for almost every nut & bolt on the car, but (I know I'm wrong) since I've been changing my oil, I just use the "snug it up" method on all my cars..
And yes I have built very Hi Po motors for a Comp eliminator car that turned over 11,000 rpm, & you can bet your life every nut and bolt was torqued EXACTLY to spec... even ones that you don't think matter (valve covers)
But for a quick oil change I have never torqued it, same goes for the tires on my Cobalt... however on the Vette which sees a lot of time on the 1/4 mile I DO torque the wheels when i swap to DR from street tires...
__________________
John Panuzzo
"When I die, I want to die like my grandfather, who died peacefully
in his sleep. Not screaming in panic like the passengers in his car."
05 C6
Best ET 11.61 @ 118 mph
Vararam, KOOKS Headers, FTI Converter,
160 T Stat & Tuned By Cartek
2004 NHRA Div 1 Finalist
jpee@comcast.net
Join the Corvette Challenge
I LUV INSANITY RACING.........
jpee is offline   Reply With Quote
Old 08-17-2010, 09:56 PM   #5
llllorac
CF Member
Oil Pan Drain Plug 25 Nm 18 lb ft .... thanks I found it on David Farmer's site and it confirmed the spec I had gotten elsewhere.... why I asked again was that having changed the oil today, I questioned whether 18 ft lbs or 216 inch lbs as I did it was enough....glad I used a torque wrench, I'm quite sure I would have been going for more and steel bolts threaded into aluminum threads are notorious for problems from over tightening....thanks again...this site is a wonderful source of informion...all fired up...I'll be at Road America this weekend...this Vette's 1st Corvette Corral outing...will be cheering for #3 and #4....
Old 08-17-2010, 11:32 PM   #6
MarkRx
CF Senior Member
MarkRx's Avatar
18 sounds about right, i was thinking 14 for some reason. careful not to over tighten no matter what, costly mistake. make sure the rubber gasket is clean and the surface on the pan.
MarkRx is offline   Reply With Quote
Reload this Page 2010 GS LS3 oil drain plug torque spec?
Tags
2010, c6, corvette, covers, drain, filter, ls3, motor, oil, plug, service, specification, specifications, specs, torque, valve, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
