Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C6 Tech/Performance
LS2, LS3, LS7, LS9 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
21st Century Muscle Cars
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-03-2010, 07:11 AM   #1
corvet786c
CF Senior Member
corvet786c's Avatar
Default What is the Best Spark Plugs for C6?
Is it NGk's like the LS1's or diffrent?
corvet786c is offline   Reply With Quote
Old 08-03-2010, 08:34 AM   #2
dennis50nj
CF Senior Member
dennis50nj's Avatar
Quote:
i race so i read the plugs often, so i use tr55 and just change them since they are cheap
__________________
Quickest/fastest stock internals/bolt ons only C6
10.62@126.98mph on a 1.411 sixty foot
Kooks long tubes/X-pipe, 160 t-stat, Corsa cat back, Vararam CAI, Cartek ported FAST intake & throttle body, Cartek fan module, underdrive pulley, high stall torque converter, gears, EWP, drag radials/skinnies, all installed and tuned by Cartek Racing The First C6 BOLT/ONS ONLY in the 10's
10.59@130+mph FASTEST CAM ONLY C6
10.16@131.08 H&C 1.35 60FT 1/8 106.45 mph
dennis50nj is offline   Reply With Quote
Old 08-03-2010, 02:16 PM   #3
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
If your car is lightly modded or mostly stock ,the Delco plugs are the best. I have seen so many driveability issues recently with NGK's installed in reletively stock cars. I have swapped out NGK's for delco plugs in over a dozen cars recently for random drivability issues directly related to the plugs. Everything from P0300 codes to carbon tracking on the plugs.
I did a back to back comparison on Delco plugs vs NGK's in our LS2 Trailblazer SS and we lost 8 RWHP with NGK's. I still run them in the TBSS because it has a 125 kit on it, but I would not touch them in a stock car. I am running the AC Delcos in our Cammed Z06 without issue.
RichieRichZ06 is offline   Reply With Quote
Old 08-03-2010, 02:55 PM   #4
theofel
CF Senior Member
St. Jude Donor '10-'13
theofel's Avatar
I have a real problem believing there is 8 RWHP difference when installing any plug with the right heat range. Let's see some dyno graphs. I would love this to be true...I certainely would like to see another 8 RWHP! Better than adding a Fast intake to my Bolt-on LS3.
theofel is online now   Reply With Quote
Old 08-03-2010, 03:11 PM   #5
NYC6
CF Senior Member
NYC6's Avatar
Quote:
Im not buying it either.
NYC6 is online now   Reply With Quote
Old 08-03-2010, 04:05 PM   #6
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
Here are the graphs. 1st run is baseline with stock plugs and no tune, 2nd is with long tubes, tune and NGK's, 3rd is back to Delco's with no other changes in the tune. I felt that after adding the LT's it should have picked up more so we were wondering why. We put the stock AC Delco plugs back in it to eliminate that variable and came up with an additional 8 RWHP.
Click the image to open in full size.
Old 08-03-2010, 04:11 PM   #7
NYC6
CF Senior Member
NYC6's Avatar
Theres some other factor at work here. Dont know what it is but Im confident you're not getting 8hp with just a plug change, unless theres a gap difference, wrong heat range, bad plug or something not quite the same from test to test.
Old 08-03-2010, 04:33 PM   #8
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
Quote:
Gap was double checked, heat range was the same, part numbers for the application were verified etc. This is not my first BBQ
This is not the only time I have seen something similar. I work at a dealer and we see 30-40 forum cars a month, all with unique issues. Recently I have seen a ton of issues with aftermarket plugs and drivability issues. I only posted this for people to see facts, not some keyboard commando baised opinion with no supporting facts to back it up. Take it for what it's worth and if you don't believe it, no biggie. I am not going to lose any sleep over peoples doubts on this issue when I see it on a weekly basis.
Old 08-03-2010, 04:42 PM   #9
dennis50nj
CF Senior Member
dennis50nj's Avatar
that plugs brand new out of the box, diferent brands could make a big diference, im not sure on the dyno numbers but i have seen .15 gain at the 1/4 and also a loss of .30 with less then a 100 street miles on some brandsi have never had a problem with the ngk, i always just coat the iner spark plug boots with a qtip and dielectric creme
Old 08-03-2010, 05:24 PM   #10
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
Quote:
.15 gain or loss would account for about 8-10 HP, which would be consistant with what I found. Both of the sets of plugs were brand new and the gap was checked just to eliminate that variable.
The only reason that made me think to do this comparison was seeing so many recent issues with aftermarket plugs on Corvettes. Using that logic on the LS2 TBSS, this is what i found.
The dielectric grease is a good idea to keep the boots from sticking on the plugs as well.
Old 08-03-2010, 07:26 PM   #11
LS1LT1
CF Senior Member
LS1LT1's Avatar
Send a message via AIM to LS1LT1
LS1LT1 is offline   Reply With Quote
Old 08-03-2010, 07:52 PM   #12
Mez
CF Senior Member
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
In my opinion, the AC Delco plugs are just as good if not better than the other spark plugs on the market. I don't believe thereis anything to be gained by change them out to another brand including NGK for a stock or mildly modded engine.
Mez is offline   Reply With Quote
Old 08-03-2010, 08:13 PM   #13
Mike's LS3
CF Senior Member
Mike's LS3's Avatar
Are we talking about Delco's iridium plugs? How often should plug wires and plugs be changed for optimal performance on a stock LS3? I know the owners manual states 100k miles. Did the 08 LS3's come with Delco iridium plugs? Thanks for any response.
Mike's LS3 is offline   Reply With Quote
Old 08-03-2010, 08:24 PM   #14
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
Quote:
Originally Posted by Mike's LS3 View Post
Are we talking about Delco's iridium plugs? How often should they be changed for keeping optimal performance on a stock LS3?
Yep, the stock Iridium plugs. I change mine every 10k miles, but that is excessive. We beat the **** out of our car every chance we get including Auto-X, HPDE's and drag racing so I like to keep them fresh.
Depending on driving habits, racing etc, I would change them every 25k on a mildly modded engine or less frequently on a stock one. I see cars come in here with 50k-75k on stock plugs and they still run great.
Old 08-03-2010, 11:57 PM   #15
LS1LT1
CF Senior Member
LS1LT1's Avatar
The factory/stock Corvette AC Delco plugs are Iridium?
I thought they were Platinum but I guess not.
Old 08-04-2010, 02:53 PM   #16
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
They have been Iridium for years.
Old 08-04-2010, 03:17 PM   #17
theofel
CF Senior Member
theofel's Avatar
If that dyno graph is from a LS3 with the mods you quoted...those #'s are about 60 t0 85 hp shy of what they should be! Even without mods they are 35 t0 50hp off. I'm willing to give the Delco another try when I change out my NGK tr55's. Thanks for your input.
Old 08-04-2010, 03:36 PM   #18
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
In the previous posts I stated the dyno graphs were from my LS2 Trailblazer SS with Long tubes and cold air.
Old 08-04-2010, 05:47 PM   #19
Gering
Tolero Apto Victum
Support Corvetteforum!
Gering's Avatar
RWHP - 440.786 RWTQ - 439.494 I love to drive!!! http://togetherweserved.com/ http://www.coasttocoastam.com/ http://www.survivalistboards.com/
Brisk USA plugs work great for me.
Gering is offline   Reply With Quote
Old 10-05-2011, 06:33 PM   #20
IrishC6
CF Senior Member
IrishC6's Avatar
I just had longtubes and cam installed on my 08 C6. Would the delco's still be OK for this application?
IrishC6 is offline   Reply With Quote
Reload this Page What is the Best Spark Plugs for C6?
Tags
2007, 2008, 2009, best, c6, corvette, gap, ls3, nitrous, plug, plugs, size, spark, sparkplugs, thread, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
