RPO Z16 vs. FE3 or FE4
Old 08-02-2010, 10:00 AM
Dan Wendling
Dan Wendling's Avatar
Default RPO Z16 vs. FE3 or FE4
What is the difference between the suspensions in the Z16 vs FE3 or FE4 suspension RPOs?
I have a 2010 Grand Sport with an Z16 Performance Package (standard). But cant figure out which suspension it includes.
Old 08-02-2010, 11:04 AM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
FE1 is the base C6 suspension
FE2 is the F55
FE3 is the Z51
FE4 is the Z06
FE5 is the ZR1
So.....I don't know what suspension comes with the Z16 package, but I suspect it's the FE3 or possibly the FE4.
However.....just go out to your glove compartment and take a look at the sticker on the door - it has all the RPO codes built into your car, and I believe that even if it lists Z16 that it will probably also have FE3 (or whatever suspension you have) listed in the list.
Let us know what you find!!
Bob
Old 08-02-2010, 01:14 PM
Dan Wendling
Default FE3 it is
FE3, Z16 and Z51 are all listed on the RPO sticker.
Found a list of all the RPOs at:
http://www.corvetteactioncenter.com/.../2010rpos.html
Old 08-02-2010, 01:29 PM
BEZ06
BEZ06's Avatar
Aha!!!! The Z51 lives on in the Z16 Grand Sport!!!
Good info - thanks!
Bob
Old 08-02-2010, 09:10 PM
RicK T
RicK T's Avatar
Well, sort of. We went through this in a couple threads last month. This is what we determined based on a member who modded his base C6 to GS specs with the help of Gene Culley advising on the GS part numbers:
The Grand Sport suspension is:
......Z51 springs and front sway bar
......Z06 rear sway bar (this kind of makes sense)
......Z06 front shocks
......UNIQUE rear shocks
Old 08-03-2010, 07:10 AM
Dan Wendling
Default Shock Dyno for 2010 GS
Anyone know where I can get shock dyno or comparison data for the "unique" 2010 GS rear shocks.
Curious why the GS does not use Z06 rear shocks?
Also the Helms calls out a difference in camber settings between FE03 and FE04.
FE03 (F/R) .45/.45 degrees
FE04 (F/R) .95/1.2 degrees
All else is the same.
So why should I not set my GS to FE04 alignment specs?
To RPO Z16 vs. FE3 or FE4
Quick Reply: RPO Z16 vs. FE3 or FE4
