3.42 diff question
The differential housings are different, the gears for the A4 are physically smaller as well as a different ratio. 3.42 gears are made for the larger housing manual trans. From what I understand somebody is making smaller 3.42 gears that will fit the smaller housing.
Also; The complete manual diff won't interchange either due to bolt patterns, input/output shaft diameters and lengths.
Your best bet is to contact any of the Forum Vendors that do rear gearswaps, they can explain the options better than I can.
From previous posts over the last couple of years;
If they are from the same year they should work. I believe they changed the case and mounts in 06+ due to the "weak" rear in the 05 models. RPM sells and adapter or something of the sort so 05 guys can put 06+ rears in.
if i put the second generation rear in my c5 i have to use the rpm adapter and an 06-10 manual case housing and side covers, i can buy that from gene culley, and use my 05 ring and pinion with my 05 differential, what changed was the housing, the a6 housing is different
The 3.42 differential from a 2005 mn6 will bolt right up to your 2005 a4, no modification required. You will have to reprogram the computer however. Everything is a straight remove and replace bolt on.
You only run into problems when you try to put a 2006+ differential onto a 2005 tranny.
