ZO6 H Pipes from 06-013 are they all the same?
I,m currently in the process of buying all the hardware that I need to update my 08 LS3 w autotrans, exhaust system with ZO6 exhaust components. My Mechanic suggest the last item I need to purchase is a H pipe but I need to know if All the ZO6 exhaust H pipes from 06-013 are the same? And are the ZR1 and the ZO6 H pipes the same pipe?
Thanks again Boonie.
- You must use the 2006-2011 main cats with the 2006-2010 or the 2011 mid pipe
- You must use 2012 or 2013 main cats if you chose to use the 2012 or 2013 mid pipe.
2009-2011 ZR1 mid pipes are the same as the 2011 Z06 mid pipe
2012-2013 ZR1 mid pipes are the same as the 2012-2013 Z06 mid pipe
Bottom line.....Determine what year main cats you have and buy a mid-pipe accordingly. The X seems to be preferred, but an H will work just fine if you have 2006-2011 main cats.
In addition, due to changes in the flange on the main cats and mid-pipe unique to the Z cars...
"X" pipe vs "H" pipe differences is that "H" pipe has a deeper tone. No significant HP gains, correct?
Sacramento, California. I visited a recycle yard Friday and was quoted a price of $400.00 for a used H pipe and Ebay has new Corsa X pipes for $440. H pipes on Ebay are selling for $195-$300 but you have to pay almost $100 for shipping, where as the Corsa X pipe comes with FREE shipping. so what do you think?
