TSB for Oil Leaks
TSB for Oil Leaks
Here is the TSB for the oil leak on 2003-2010 Corvette (as well as numerous other GM products. This applies to 5.3L, 5.7L, 6.0L, 6.2L,7.0L
Bulletin No. 05-06-01-0341.
It is titled "Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure).
It was obtained from Alldata.
Hope this helps.
Hope this helps.
Where is the TSB you speak of?
