Z06/Grand Sport
1 Post
Z06/Grand Sport
I know the G/S has the body, wheel size, dry-sump oiling system of the Z06. Does it also share the brakes, clutch, manual trans, and rear diff with the Z06? Anybody know?
TIA
Jeff
TIA
Jeff
The dry sump is only on the manual trans coupes. Not on verts, Not on autos. Yes this moves the battery to the trunk and it is the newest version oil tank in the passenger fender. Same exact brakes execpt silver calipers vs. red on Z.
Same transmission in all manual C6 Corvettes 2008-2010.
Different manual transmission gearing in the Z51 equipped and grand sport C6, than in the base manual and Z06.
Same 3.42 differential gears in all manual C6 Corvettes.
Seems to be the one going. If you can't swing the Z, then I guess the GS is a real good choice.
St. Jude Donor '09
San
It's the newer version but at least one major vendor has expressed less than flattering comments about the Z06 dry sump system, which is the same as the GS' from what I've read. You'll find better information on the Autocrossing and Roadracing forum, as well as information on the LS3 oiling issues. PM me if you want a bit more detail.
San
San
Dry sump is a non-issue for me as for probably 99.9% of potential GS owners. Removable roof panel and Z51 gearing are BIG factors favoring the GS over the Z06 in my book.
