Power steering and brake fluid changes.
On a 2005 Corvette that is not driven on the track but used once a week or sometimes as a commute car how often should the brake fluid and power steering fluid be changed?
I wouldn't worry about the Power Steering, but its a good idea to do a brake fluid flush every 30K or 2years to maintain best performance with the ABS system. If you want to get the most out of your system, switching to stainless steel lines when you do a flush will also give you much better pedal feel and repsonse.
