Heated Seats
Navigator
Heated Seats
Yesterday it was even cold in Florida and i tried to use the heated seats in my 08 Z06. the red light came on but turned off after a second. no chance to switch to low heat or to keep it on. i tried the pax side and this side worked. any clue?
thanx
tom
thanx
tom
Former Vendor
Might wanna take it to the dealer? Sounds like somthing is fubared.
Mine did the same identical thing last winter..The red light would come on then go right back off..I pulled the seat up to find one of the wires was pulled out of the plug, i had to reattach the wire and also replace the fuse because it caused it to blow..Then it was good to go..Hope that helps...
Jonathan..
Jonathan..
Just a thought. I don`t know if the heated seats are tied into the hot air system or not. Try turning up the heat for the entire car and see if the heated seats stay on.
Navigator
thanks guys for the help. i didnt had the chance to look at it. but right, i rather look at it first by my self then bringing it to the dealer were the mechanics ripp off everything and dont get it back together.
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Pull the seat and check the wires/connectors. Takes only a few minutes to get the seat out. The connector and wires under the seat get pinched due to the tight space there. Pretty straight forward.
