Loss of hatch pull down
My hatch pull down will occasionally stop working. It works fine again after putting the battery on charge for several hours. The car is run daily.
My dealer checked it out exhaustively & can't fine anything wrong with the battery, charging system, or any of the modules involved. In desperation, he suggests putting it on a battery maintainer.
daily driver being put on a maintainer.......i don't think so!!! sounds to me like the battery is giving up and has a weak cell or cells. your profile shows a 2009 z51, it should still have warranty...get the dealer to replace the battery or replace the auto closer. It may be defective. If they won't, go to a dealer who will.
This has become a soap opera. In the beginning, it only occasionally wouldn't pull down. As time passed, it happened more frequently until yesterday it wouldn't actuate at all. I thought maybe charging the battery was just coincidental & the real problem might be the failure to always close the switch in the unit; so I shot it with WD40 & left it over night. It has been flawless today. I run it every time I go by.
