ok. so this is secong time in 4 days. just bought a brand new battery and it is completely dead. everything is shut off in the car, no lights etc. what is draining the battery
No doubt. These cars are finicky about shutting down. I installed the "XM version" of Lockpick and dead battery. I called them, they sent the "non-XM version" and all is well.
Maybe Kenwood has some similar instructions for the Vette.
thanks guys
it was the navi. the little blue box that runs the radio and speakers was not cutting off, so the battery was going dead in about 4 hours. it is fixed now, i swapped the boxes out.
thanks guys
FYI. since you ran the battery dead several times, unless it is an AGM type battery such as an Optima, you have really hurt the battery. Standard flooded SLI batteries are not made to take that abuse. It may not be a problem today, but it will be later and then you will want to blame the battery.
its an optima, and each time i ran it dead, i took back and got a new one.
thanks
