Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- How to Install Methanol Injection
Step by step instructions for do-it-yourselfers.
METHheadMONSTER: Using Meth Injection for non-boost applications
Thanks for the write up, we've been looking at doing this to my car for a while now. I know this question is alittle off topic, and might start a debate, but thats how we learn so.....Would you consider adding a meth system to the car and running it with 93 octane, equal to running 100 octane. Reason I ask is because a lot of times we get to a road course and the pumps are not on. Normally I fill the car at E-town with 100, and take 20 gallons of 100 with me in truck. By the second day, sometimes I don't have enough of100 to finish my runs and I end up going home early. Getting the fuel before hand, and hauling it to Watkins Glen, or Pocono is a pain in the rear sometimes.
If this is allowable, I'd consider this mod for my C5Z in the Texas heat.
1 Post
St. Jude Donor '09-'10-'11
Thanks for the info
Does anyone know who it was that was selling the fenders already painted as a package deal with shipping and all parts in the kit?
Locals here are getting silly with the pricing for painting loose panels. In NY you could get it done great for 350 for both. Here I'm hearing 600+.
I can get the fenders for 1220 shipped but the painting is silly.
As to the fenders already painted, you may want to contact Corvette Recyclers in Utah who are Forum vendors (801) 447 4700
I dont really understand the question.
Meth injection is north of 110 octane and most places state its a 116 octane. 100 octane is a step down and it wouldnt give you the cooler IATs from the spray injected into the intake.
Would I add meth injection to 93 octane? Thats what this thread was about. What did I miss?
With the amount being sprayed, it will last the whole day on a single tank. When it gets low the DIC will read low WW fluid.....exactly what it is. You can bring two gallons of WW fluid or whatever you use as the meth.
Doug at ECS says he dynos more with 100% meth but when you look at the gains the percentage drop from the 60 or 70hp you pick up is probably 50-55 with 50/50 or WW fluid. I tend to agree with Doug's results so I think 100% makes more power. 50/50 makes 75-80% and 40% WW fluid would likely make slightly less than 50/50 at about 70%.
There are some failsafes built into the system.
First, the system has an LED that lights to tell you if the system is firing. There is a test button to test the pump before anything serious is done with the car.
Also, as I stated in the OP, it is recomended that you use an IAT located downstream of the nozzle. When it sprays, it lowers the IAT and this then consults the IAT vs spark advance table. The table pulls timing in relation to the outside temps which drop when meth is sprayed. In this set-up if the meth doesnt spray, the IAT's dont fall and it pulls out some timing. In this table you see how after the ambien temps hit 86 degrees, the car starts pulling timing. When meth sprays it lowers the temps and the car wont pull the timing. If the car hits 104 degrees, its pulling up to 6 degrees and thats about 20HP right there. This wouldnt be pulled if the car was spraying and the IAT's were reading 85:
The knock sensors will pull timing in a knock event and to get 15-20HP you need 4-5 degrees. The car can pull up to 15.
There are also two outputs that can be connected to various relays and such. On my car i made it so the neg output is required to fire to activate a nitrous shot.
Lastly, some of the gains from using MEth are seen without altering the tune. The car's existing safe tune will benefit in hot envirnments because it will lower IAT's and this is good for power in the same way a car makes more HP on cold days. Part is that cold air is more dense and part is that the car wont be pulling timing on a 100 degree day if it reads 70degrees while meth is being shot. This is power gained with your car's present stock tune. If the system fails the car runs the way it does before the system went in.
I didnt retune for meth yet on my FI car. I note a serious gain with no added timing and with it running pig rich.
If I had to guess, I'd say it will gain 20rwhp without being tuned for it on a car running in very hot climates. Zero risk for you Texas guys. I'd be all over this. I think a Texas car on 100 degree days will make 30rwhp with the meth system adding 3 degrees timing and leaning out the fuel mix back to 13:1 with the system spraying. Same deal in NY with 90% humidity and 97 degrees outside plus its great piston protection.
I hope this helps.
For those that want the extra 3HP use 50/50 or 5hp more with 100%.
WW fluid is legit meth for the system. Using water injection or 50/50 mix wont extend the fuel system any so that benefit is lost but how many N/A cars are over 600rwhp? It would apply only to cars looking to make the most from N/A fuel system requirements. If you needed more than the stock system can supply you can beef it up in other ways such as using ECS' new base parallel fuel system with its 650+rwhp pump or if you like to punish yourself you can upgrade to the Z06 intank fuel pump. I added the parallel fuel system which can be triggered by rpm for N/A cars ( it uses a hobbs switch on Fi cars to activate under boost. On my gauge pillar, its the yellow LED next to my wideband that tells me when the fuel system is adding the output from the second pump.
A great read on the effects/benfits:
http://www.alcoholinjectionsystems.c...icle_info.html
Things I didnt know:
Methanol cools way better than water. Methanol only cars (use of meth as the fuel) doenst need an intercooler on FI engines and some drage cars running it dont even need a radiator.
It states that 50/50 mixes of water/meth arent flamable but when I read a WW gallon bottle it said it was flamable. Is WW fluid more than 50% meth?
The cooling effect come from the water/meth absorbing the heat instead of the cylinder walls.
Water injection increases dynamic compression while increasing octane rating of the fuel.
Upgraded Stage 2 Progressive Water Methanol Injection Controller
I see that Alcohol Injection Systems also has a controller.
Anyone with experience using this other controller?
From the description below it uses MAP sensing via an air pressure line not electrical MAP output as the primary sense. But it has an additional input for electrical connection to other sensors. Sounds fairly advanced but I have no idea how to take advantage of it, nor what the benefit would be to the progressive 2D mapping of spray. Looking for those that know to comment.
One more question:
In Spins latest post he mentions locating the IAT downstream of the meth spray nozzle, but spraying into the MAF is a no no. So in a stock intake system the MAF and IAT are the same unit so what do you do? In my case I have a Killer Bee intake but this uses the stock MAF/IAT sensor so I have the same issue as the stock intake, where do I mount the new IAT?
Simply begin by running a boost signal from manifold pressure to the boost port (brass nibble) located on the side of the programmer. From there you can quickly set the activation point, from 1-30psi, using the green ****. Next, the middle gray **** (Tune) with 10 positions allows you to control the maximum duty cycle of the pump. This is great for fine tuning in situations where you need to lower or raise the flow. Lastly, you have the red **** which allows you to control the rate of increase. For example, setting it a 15psi would allow the system to go into full flow once 15psi was reached. You can also bring the system in quicker by setting the red **** sooner. For example, setting the red **** at 10 psi even though the motor actually reaches 15 psi. This will increase rate of increase and vise versa.
Once activated the system will spray a progressive amount of fluid through the nozzle or nozzles based on the custom map you have set. Flow will also reduce proportionally as boost drops off and will not turn off until boost drops back down below the set activation point. Users can also turn the system into a two dimensional system by including any of the following 0-5v inputs; TPS, MAF, MAP, EGT and AIT, for even greater control and custom mapping which isn't offered by the competitors systems.
Last edited by Dan Wendling; 09-27-2009 at 04:12 PM. Reason: Figured out Alcohol Injection Systems and Alky Control are not the same company
St. Jude Donor '05-'08
Hi George,
I think what George is asking
His car is set to run 93 octane on the street, but when pushing it on the track (road race not 1/4 mile) he is required to run 100 octane (this is what is available at the track) as a safety measure.
If instead of worrying about buying 100 octane which some track notoriously run out of or dont have if he could instead put a meth system in would that be a good substitute.
A few questions for you Spin for RR application (if you are not sure that is fine I am just trying to gain knowledge):
My RR car runs between 4800 - 6800 for 40 min clips. Is there enough in the WW to cover that time?
RR cars are shifting up and down but still holding rpms. As an example I might be at 6000 rpms and slowing down for a turn so I slam on the brakes, rev match and enter the turn at a slower speed but the same rpms (6K). Can the system handle that? There cannot be any delay with the meth because we know what the consequences could be.
So my 2 questions are:
1. How much will I be using on a RR course.
2. Is there any delay between when I need meth and when I get it.
thanks
All of the cars on that road course are running the course with windsheild wiper fluid in the existing tank which is what corvettes use as the meth tank. So just use WW fluid as your meth. WW fluid will work with 80% percent of the gain of 100% meth so dont change it. Use the WW tank with the same fluid it came from the factory filled with. That is meth and it will work just fine. By the way, the fluid we use as WW fluid is flamable so they are full o crap. Anyway, thats what you use. If not, water injection is 1/2 of the benefot and adds to octane rating too. Thats not flamable.
WW fluid is legit meth for the system....
Good point, thanks Spin
It is instant since the fluid level in the line going to the nozzle never backs off. There is a check valve that keeps it from flowing backward.
I had to take my car apart this week after it was sitting for about 10 days. When I disconnected the nozzle, the meth was right up to the tip still and hadnt backed off. It will spray instantly when you roll into it.
#33
I've been following this thread and while I found this Mod very interesting, I wasn't sure this was something I would ever consider. The more I read, the more I think "You know, I could do this"! I know Meth is adictive but this is ridiculous.
#34
One more question:
ECS is aforum tuner and you should be sourcing the parts from them. You will not need a 2 bar MAP sensor so that will lower the price about 550. Dont shop by price with this level of technology. Buy the 499 system you see in your thread is saving 50 bucks is asking for trouble when it comes to after the sale support. ECS wont drop the ball.
You should buy from a corvette tuner to get it to work on a corvette. Doug and Chris know this car.
The IAT sensor I mentioned was specifically the one out of the MAF used on the F-bodies. It is separate from the MAF which is before the nozzle.
#35
2017 C5 of the Year Finalist
St. Jude Donor '08
I just thought I'd share how to make it work and variables to get it optimized from Fi applications. The general idea was to show how it goes in and what it does as far as how it operates.
JB's car runs torco so the octane boost thats there from the torco actually decreases the gains for meth since redundant octane boosts do the same thing. In other words, his car had meth added to the HP the car had with torco so he may have seen 20rwhp from meth alone if the car wasnt already running an octane boost tune before the kit's install. what I like about the re-dyno with meth is that it shows what octane boost cant do on its own and how much further up the power ladder meth goes.
Thanks for posting.
Thanks for posting.
Yes, I do believe that running Torco first, and then adding Meth, diminishes the gains of adding the meth alone, since my octane and timing had both already been raised. That being said, I still like the positive effects of running both, since the meth is only triggered to come on in the mid to upper RPMs, and when intake manifold pressure get very close to zero. Having the higher octane all the time allows for a more aggresive tune across the board, as well as a degree of safety.
I've now got 20K on my car, and it still runs like a top!
JB
#36
Let me know if you need help with it. I installed mine pretty much free of issues and can help save you time.
#37
Very nice write up Spin!
JB
JB
The unit can be made to hit very low in load with a small initial hit and rising so I think the midband boost can be there too. I can get it to hit at any rpm and with 1/2 load.
Smaller misting nozzles are available. I'm in contact with Alkycontrol about this. There are other sources for nozzles specifically for N/A meth use.
#38
Julio from AlkyControl has contacted me about this thread and provided me with nozzle info and to stress the need to install the unit inside the car. It is not weather proof so dont do what I did and put it inside the car. I had planned to move it sooner than later.
Julio:
Jason,
A couple of things. First thanks for the writeup. I need to make some corrections, give you the flow rates on the nozzles, and give you some ideas.
First, technically the controller should be inside of the vehicle, the reason is that it is not weather proof. If you drive in the rain, wash the car/engine, etc and water gets into it.. bad things can happen. And having the test button inside the car will allow you to "pre-test" the kit.
Ok.. that said, the nozzles have a printed number on them, typically the kit comes with an M15=15 gallons per hour at 100 PSI. Typically an 8 cylinder application on straight alcohol will use an M15 up to about 650 RWHP typically. A 400 RWHP application will use a 10 GPH nozzle with our system. This is based on pump pressure/volume. And when using water, you drop the size down further as it becomes easy to make a mess. So I would say a 5-7 GPH nozzle for water
Now.. here's one issue I see. If you set the kit to activate under low vacuum using the MAP, when you turn the ignition ON.. you technically are activating it. Also MAP doesnt account for varying load conditions/rpm. A better way would be to inject based on "LOAD" but that technology is not available yet.
Now I have a converter I built a month ago to tie our kit into a GM alternate signal source. (The info here is in developement and has been deleted from this post for confidentiality of Julio's work.)
So if you want to guinea pig it.. i'll be more than happy to send it your way for testing.
Now.. next item.. meth vs mix. I guess it depends on goals. If you increase the volume of mix and the car loses power or sputters.. then you need to increase the methanol concentration. Every car is different. With nitrous i'd probably ditch the water altogether.
Anyways.. when you can get some free time during the week, drop me a call. be happy to assist you any way I can.
Based on Julio's advice I would use the MAP for the trigger with an RPM on switch for low load use (not a window switch unless you set the high RPM off above the engines use range). High load will not output a voltage high enough to trigger the system as in JB's car. This will prevent the spraying of the system upon start-up. I will keep everyone current on the use of the experimental trigger.
Julio and ECS give this kind of support so dont fool yourself into thinking that saving 50 bucks on the 'other' system is a good idea.
Thanks Julio for the quick response.
Julio:
Jason,
#39
Thanks Spin.
Doug and I have talked about this off and on for some time now for the RR cars. As of this year we decided to continue to use 100 octane at the track but having more data from others could change our future considerations.
Bob
Bob
#40
I haven't used that system. All the pumps used from various vendors are modded from the same pump so its about the electronics used with it.
Might be worth waiting for Juilo's new controller that I hope you offer to beta test.
Regards the IAT install. Do you have any pictures of where to install with a stock intake or even better with a Haltech Killer Bee? Or perhaps the idea is to use an ECS charge tube with an air filter in place of the inter-cooler.
